BIN = helloworld
BIN_ASM = $(BIN).asm
OBJEXT = .o
CC = ${LITEOS_COMPILER_PATH}/bin/$(CROSS_COMPILE)gcc //这里用的是交叉编译工具gcc,而非是官方python脚本用的是clang, 直接make出错
CPP = ${LITEOS_COMPILER_PATH}/bin/$(CROSS_COMPILE)g++
LD = ${LITEOS_COMPILER_PATH}/bin/$(CROSS_COMPILE)ld
OBJDUMP = ${LITEOS_COMPILER_PATH}/bin/$(CROSS_COMPILE)objdump
COMMON_INCLUDE = -I $(APP_DIR)/include/
COMMON_FLAGS = -fPIE -D_XOPEN_SOURCE=700
CFLAGS += -fno-omit-frame-pointer -std=c99 $(COMMON_INCLUDE) $(COMMON_FLAGS)
CXXFLAGS += $(COMMON_INCLUDE) $(COMMON_FLAGS)
ifeq ($(STATIC_COMPILE), y)
LDFLAGS = --static
else
LDFLAGS = -pie
endif
CCSRCS := $(wildcard *.c)
CCOBJS = $(CCSRCS:.c=$(OBJEXT))
CXXSRCS := $(wildcard *.cpp)
CXXOBJS = $(CXXSRCS:.cpp=$(OBJEXT))
MUSL = musl/lib/libc.so
all: $(MUSL) $(BIN) $(BIN_ASM)
$(CCOBJS): %$(OBJEXT): %.c
@echo "CC: [ DISCUZ_CODE_51 ]lt;" $(Q) $(CC) -c $(CFLAGS) [ DISCUZ_CODE_51 ]lt; -o $@
$(CXXOBJS): %$(OBJEXT): %.cpp
@echo "CPP: [ DISCUZ_CODE_51 ]lt;"
$(Q) $(CPP) -c $(CXXFLAGS) [ DISCUZ_CODE_51 ]lt; -o $@
$(BIN_ASM): $(BIN)
$(Q) rm -rf $(CCOBJS) $(CXXOBJS)
$(Q) $(OBJDUMP) -d $(BIN) > $(BIN_ASM)
$(MUSL):
$(Q) rm -rf musl/
$(Q) ./build_musl.sh &> build_musl.log
$(BIN): $(MUSL) $(CCOBJS) $(CXXOBJS)
@echo "LD: $^"
$(Q) $(CC) $(LDFLAGS) -o $@ $^
else
@echo "LD: $^"
$(Q)mkdir -p $(APP_DIR)/lib/
$(Q)cp -f $(APP_DIR)/src/musl/lib/libc.so $(APP_DIR)/lib/libc.so
$(Q)$(CC) $(LDFLAGS) -o $@ $(CCOBJS) $(CXXOBJS)
endif
clean:
$(Q) rm -rf $(CCOBJS) $(CXXOBJS) $(BIN) $(BIN_ASM)
$(Q) rm -rf musl/
$(Q) rm -rf build_musl.log
install:
$(Q) mkdir -p $(FSIMG_DIR)
$(Q) install $(BIN) $(FSIMG_DIR)/$(BIN)
