Eric
你好,拿掉仿真器后,除了CLAmath运行不正常外,其他的都正常。下面是cmd文件。
#define USE_CLA_C 1 /* 1 = Using CLA C-compiler, 0 = ASM only */
/* Define size for the CLA scratchpad area that will be used
by the CLA compiler for local symbols and temporary variables; Also force
references to the special symbols that mark the scratchpad area. */
#if USE_CLA_C == 1
CLA_SCRATCHPAD_SIZE = 0x100;
--undef_sym=__cla_scratchpad_end
--undef_sym=__cla_scratchpad_start
#endif
MEMORY
PAGE 0 : /* Program Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
RAMCLAProg : origin = 0x009000, length = 0x001000 /* on-chip RAM block L3, CLA Program RAM */
RAMFuncs : origin = 0x00A000, length = 0x002000 /* on-chip RAM block L4 */
OTP : origin = 0x3D7800, length = 0x000400 /* on-chip OTP */
FLASHH : origin = 0x3D8000, length = 0x008000 /* on-chip FLASH */
FLASHF : origin = 0x3E0000, length = 0x004000 /* on-chip FLASH */
FLASHE : origin = 0x3E4000, length = 0x004000 /* on-chip FLASH */
FLASHD : origin = 0x3E8000, length = 0x004000 /* on-chip FLASH */
FLASHC : origin = 0x3EC000, length = 0x004000 /* on-chip FLASH */
FLASHB : origin = 0x3F0000, length = 0x004000 /* on-chip FLASH */
FLASHAPP : origin = 0x3F4000, length = 0x001FF0 /* on-chip FLASH Sector A. */
APPENTRY : origin = 0x3F5FF0, length = 0x00000C /* on-chip FLASH Sector A. Application entry address */
DEVICEINFO : origin = 0x3F5FFC, length = 0x000004 /* on-chip FLASH Sector A. Used for check boot whether finished or not. */
BOOTFUNCS : origin = 0x3F6000, length = 0x001800 /* on-chip FLASH Sector A. Boot functions locations */
BOOTPROC : origin = 0x3F7800, length = 0x000780 /* Part of FLASH Sector A. Used for boot process to Flash. */
CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASH Sector A. Program with all 0x0000 when CSM is in use. */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASH Sector A. Used for "boot to Flash" bootloader mode. */
CSM_PWL_P0 : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASH Sector A. CSM password locations */
FPUTABLES : origin = 0x3FD860, length = 0x0006A0 /* FPU Tables in Boot ROM */
IQTABLES : origin = 0x3FDF00, length = 0x000B50 /* IQ Math Tables in Boot ROM */
IQTABLES2 : origin = 0x3FEA50, length = 0x00008C /* IQ Math Tables in Boot ROM */
IQTABLES3 : origin = 0x3FEADC, length = 0x0000AA /* IQ Math Tables in Boot ROM */
ROM : origin = 0x3FF3B0, length = 0x000C10 /* Boot ROM */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */
PAGE 1 : /* Data Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
/* Registers remain on PAGE1 */
BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */
RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAMCLAData : origin = 0x008000, length = 0x000C00 /* on-chip RAM block L0 */
RAML1 : origin = 0x008C00, length = 0x000200 /* on-chip RAM block L1, CLA Data RAM 0 */
RAML2 : origin = 0x008E00, length = 0x000200 /* on-chip RAM block L2, CSM secure, CLA Data RAM1 */
RAML5 : origin = 0x00C000, length = 0x002000 /* on-chip RAM block L5 */
RAML6 : origin = 0x00E000, length = 0x002000 /* on-chip RAM block L6 */
RAML7 : origin = 0x010000, length = 0x002000 /* on-chip RAM block L7 */
RAML8 : origin = 0x012000, length = 0x002000 /* on-chip RAM block L8 */
USB_RAM : origin = 0x040000, length = 0x000800 /* USB RAM */
CLA1_MSGRAMLOW : origin = 0x001480, length = 0x000080 /* Part of PF0 - CLA to CPU Message RAM */
CLA1_MSGRAMHIGH : origin = 0x001500, length = 0x000080 /* Part of PF0 - CPU to CLA Message RAM */
/* Allocate sections to memory blocks.
Note:
codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
execution when booting to flash
ramfuncs user defined section to store functions that will be copied from Flash into RAM
SECTIONS
BootAPI:
-l rts2800_fpu32.lib(.cinit BootFlash)
-l rts2800_fpu32.lib(.text BootFlash)
-l F2806x_CodeStartBranch.obj(.text BootFlash)
-l Flash2806x_API.obj(.cinit BootFlash) /* Flash2806x_API.c???t?D?¨ò?μ?3£á? */
] > BOOTFUNCS PAGE = 0
/* Allocate program areas: */
.cinit : > FLASHH, PAGE = 0
.pinit : > FLASHH, PAGE = 0
.text : > FLASHH, PAGE = 0
codestart : > BEGIN, PAGE = 0
Cla1Prog : LOAD = FLASHD,
RUN_START(_Cla1Prog_Start)
RUN = RAMCLAProg,
LOAD_START(_Cla1funcsLoadStart),
LOAD_END(_Cla1funcsLoadEnd),
RUN_START(_Cla1funcsRunStart),
LOAD_SIZE(_Cla1funcsLoadSize),
PAGE = 0
Cla1ToCpuMsgRAM : > CLA1_MSGRAMLOW, PAGE = 1
CpuToCla1MsgRAM : > CLA1_MSGRAMHIGH, PAGE = 1
ClaRAM : > RAMCLAData, PAGE = 1
CLA1mathTables : > RAML1,
LOAD_START(_Cla1mathTablesLoadStart),
LOAD_END(_Cla1mathTablesLoadEnd),
LOAD_SIZE(_Cla1mathTablesLoadSize),
RUN_START(_Cla1mathTablesRunStart),
PAGE = 1
#if USE_CLA_C == 1
CLAscratch : [ *.obj(CLAscratch) /* Scratchpad memory for the CLA C Compiler */
. += CLA_SCRATCHPAD_SIZE;
*.obj(CLAscratch_end)
] > RAML2, PAGE = 1
#endif
ramfuncs : LOAD = BOOTFUNCS,
RUN = RAMFuncs,
LOAD_START(_RamfuncsLoadStart),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
LOAD_SIZE(_RamfuncsLoadSize),
PAGE = 0
csmpasswds : > CSM_PWL_P0, PAGE = 0
csm_rsvd : > CSM_RSVD, PAGE = 0
AppEntry : > APPENTRY, PAGE = 0
DeviceInfo : > DEVICEINFO, PAGE = 0
BootFlash : > BOOTFUNCS, PAGE = 0
BootProcess : > BOOTPROC, PAGE = 0
APPMAIN : > FLASHAPP, PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM0, PAGE = 1
.ebss : > RAML8, PAGE = 1
.esysmem : > RAML8, PAGE = 1
.bss_cla : > RAMCLAData, PAGE = 1
/* Initalized sections to go in Flash */
/* For SDFlash to program these, they must be allocated to page 0 */
.econst : > FLASHH, PAGE = 0
.switch : > FLASHH, PAGE = 0
/* Allocate IQ math areas: */
IQmath : > FLASHH, PAGE = 0 /* Math Code */
IQmathTables : > IQTABLES, PAGE = 0, TYPE = NOLOAD
/* Allocate FPU math areas: */
FPUmathTables : > FPUTABLES, PAGE = 0, TYPE = NOLOAD
DMARAML5 : > RAML5, PAGE = 1
DMARAML6 : > RAML6, PAGE = 1
DMARAML7 : > RAML7, PAGE = 1
/* Uncomment the section below if calling the IQNexp() or IQexp()
functions from the IQMath.lib library in order to utilize the
relevant IQ Math table in Boot ROM (This saves space and Boot ROM
is 1 wait-state). If this section is not uncommented, IQmathTables2
will be loaded into other memory (SARAM, Flash, etc.) and will take
up space, but 0 wait-state is possible.
IQmathTables2 : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
IQmath.lib
(IQmathTablesRam)
/* Uncomment the section below if calling the IQNasin() or IQasin()
IQmathTables3 : > IQTABLES3, PAGE = 0, TYPE = NOLOAD
IQmath.lib (IQmathTablesRam)
/* .reset is a standard section used by the compiler. It contains the */
/* the address of the start of _c_int00 for C Code. /*
/* When using the boot ROM this section and the CPU vector */
/* table is not needed. Thus the default type is set here to */
/* DSECT */
.reset : > RESET, PAGE = 0, TYPE = DSECT
vectors : > VECTORS, PAGE = 0, TYPE = DSECT
Eric
#if USE_CLA_C == 1
#endif
MEMORY
Note:
SECTIONS
BootAPI:
RUN = RAMCLAProg,
PAGE = 0
PAGE = 1
#if USE_CLA_C == 1
] > RAML2, PAGE = 1
#endif
RUN = RAMFuncs,
PAGE = 0
IQmath.lib
(IQmathTablesRam)
/* DSECT */
举报
