STM32
直播中
罗兰君
8年用户 234经验值
私信 关注
[问答]
使用FSMC调试B505时出现问题怎么解决
使用的是F407ZGT 的FSMC调试B505时使用LCD_CLEAR(WHITE)时显示不正常,表现:1较少几率出现为黑白相间条 2.黑白相间的刷几行就没有了
而是用其他颜色均可正常显示,B505在miniSTM32上正常工作,现象很诡异,也可能很低级,相关代码如下,请帮忙看看
RS接A16 使用NE4
FSMC初始化:
LCD_EXT void LCD_GPIOInit(void){  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;  FSMC_NORSRAMtimingInitTypeDef  p;  GPIO_InitTypeDef GPIO_InitStructure;     /* Enable GPIOs clock */  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOG|RCC_AHB1Periph_GPIOA|RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE | RCC_AHB1Periph_GPIOB, ENABLE);
  /* Enable FSMC clock */  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
  /* GPIOD configuration */  GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);//FSMC_D2  GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);//FSMC_D3  GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);//FSMC_NOE  GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);//FSMC_NWE  GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);//FSMC_D13  GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);//FSMC_D14  GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);//FSMC_D15  GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);//FSMC_A16  GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);//FSMC_D0  GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);//FSMC_D1
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4  | GPIO_Pin_5  |GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10  | GPIO_Pin_11  |GPIO_Pin_14 |GPIO_Pin_15;  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOD, &GPIO_InitStructure);  /* GPIOE configuration */  GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);//FSMC_D4  GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);//FSMC_D5  GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);//FSMC_D6  GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);//FSMC_D7  GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);//FSMC_D8  GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);//FSMC_D9  GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);//FSMC_D10  GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);//FSMC_D11  GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);//FSMC_D12
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7  | GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10 |                                GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |                                GPIO_Pin_15;  GPIO_Init(GPIOE, &GPIO_InitStructure);
/* LCD_CS Pin config as GPIOG_PIN_12 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;   GPIO_Init(GPIOG, &GPIO_InitStructure);/* LCD_BL Pin config as GPIOA_PIN_0*/GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;GPIO_Init(GPIOA, &GPIO_InitStructure);    }/******************************************************************************** Function Name : LCD_FSMCConfig* Description   : Configures the Parallel interface (FSMC) for LCD(Parallel mode)* Input         : None* Output         : None* Return         : None*******************************************************************************/
LCD_EXT void LCD_FSMCConfig(void){  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;  FSMC_NORSRAMTimingInitTypeDef  p;
/*-- FSMC Configuration ------------------------------------------------------*/  /* FSMC_Bank1_NORSRAM4 timing configuration */  p.FSMC_AddressSetupTime =0;//1  p.FSMC_AddressHoldTime = 0;  p.FSMC_DataSetupTime =2;  p.FSMC_BusTurnAroundDuration = 0;//0  p.FSMC_CLKDivision = 0;  p.FSMC_DataLatency = 0;  p.FSMC_AccessMode = FSMC_AccessMode_B;//FSMC_AccessMode_B;
  /* FSMC_Bank1_NORSRAM4 configured as follows:        - Data/Address MUX = Disable        - Memory Type = SRAM        - Data Width = 16bit        - Write Operation = Enable        - Extended Mode = Disable        - Asynchronous Wait = Disable */  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//16bit  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC_Bank1_NORSRAM4 */  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
B505驱动 读写
LCD_EXT void LCD_Init(void){   LCD_WriteReg(0x0000,0x0000);LCD_WriteReg(0x0000,0x0000);LCD_WriteReg(0x0000,0x0000);LCD_WriteReg(0x0000,0x0000);LCD_WriteReg(0x00a4,0x0001);delay(20);  LCD_WriteReg(0x0060,0x2700);LCD_WriteReg(0x0008,0x0202);LCD_WriteReg(0x0030,0x0214);LCD_WriteReg(0x0031,0x3715);LCD_WriteReg(0x0032,0x0604);LCD_WriteReg(0x0033,0x0e16);LCD_WriteReg(0x0034,0x2211);LCD_WriteReg(0x0035,0x1500);LCD_WriteReg(0x0036,0x8507);LCD_WriteReg(0x0037,0x1407);LCD_WriteReg(0x0038,0x1403);LCD_WriteReg(0x0039,0x0020);LCD_WriteReg(0x0090,0x001a);LCD_WriteReg(0x0010,0x0000);LCD_WriteReg(0x0011,0x0007);LCD_WriteReg(0x0012,0x0000);LCD_WriteReg(0x0013,0x0000);delay(20);LCD_WriteReg(0x0010,0x0730);LCD_WriteReg(0x0011,0x0137);delay(20);LCD_WriteReg(0x0012,0x01b8);  delay(20);LCD_WriteReg(0x0013,0x0f00);LCD_WriteReg(0x002a,0x0080);LCD_WriteReg(0x0029,0x0048);delay(20);LCD_WriteReg(0x0001,0x0100);LCD_WriteReg(0x0002,0x0700);LCD_WriteReg(0x0003,0x1230);LCD_WriteReg(0x0008,0x0202);LCD_WriteReg(0x000a,0x0000);LCD_WriteReg(0x000c,0x0000);LCD_WriteReg(0x000d,0x0000);LCD_WriteReg(0x000e,0x0030);LCD_WriteReg(0x0050,0x0000);LCD_WriteReg(0x0051,0x00ef);LCD_WriteReg(0x0052,0x0000);LCD_WriteReg(0x0053,0x013f);LCD_WriteReg(0x0060,0x2700);LCD_WriteReg(0x0061,0x0001);LCD_WriteReg(0x006a,0x0000);//LCD_WriteReg(0x0080,0x0000);//LCD_WriteReg(0x0081,0x0000);LCD_WriteReg(0x0090,0X0011);LCD_WriteReg(0x0092,0x0600);LCD_WriteReg(0x0093,0x0402);LCD_WriteReg(0x0094,0x0002);delay(20);LCD_WriteReg(0x0007,0x0001);delay(20);LCD_WriteReg(0x0007,0x0061);LCD_WriteReg(0x0007,0x0173);LCD_WriteReg(0x0020,0x0000);LCD_WriteReg(0x0021,0x0000);  LCD_WriteReg(0x00,0x22);
=========================LCD读写如下
LCD_EXT void LCD_WriteReg(u8 LCD_Reg, u16 LCD_RegValue){*(volatile u16 *) (LCD_CMD)= LCD_Reg;        *(volatile u16 *) (LCD_DATA)= LCD_RegValue;       }
LCD_EXT void LCD_WriteData(u16 data){*(volatile u16 *) (LCD_DATA)= data;}
//读寄存器LCD_EXT u16 LCD_ReadReg(u8 LCD_Reg){   *(volatile u16 *) (LCD_CMD)= LCD_Reg;;//写入要读的寄存器序号delay(5);  return (*(volatile u16 *) (LCD_DATA));//返回读到的值}
//开始写GRAMLCD_EXT void LCD_WriteRAM_Prepare(void){//LCD->LCD_REG = R34;*(volatile u16 *) (LCD_CMD)= R34;}
//LCD写GRAMLCD_EXT void LCD_WriteRAM(u16 RGB_Code){    //LCD->LCD_RAM = RGB_Code;//写十六位GRAM*(volatile u16 *) (LCD_DATA)= RGB_Code;}
回帖(3)
刘婷
2020-5-29 10:33:35
在MINI上是正常的,又试了下白色的0XFFFF和0XFFFE 就没有写进RAM 读取到点的颜色是上次LCDclear的值
举报
李晟才
2020-5-29 10:53:18
排除了液晶的问题.
参考一下龙元兄的代码吧.
http://www.openedv.com/posts/list/5659.htm?fromAll=0
举报
刘占宽
2020-5-29 11:11:09
代码没有变换成4531后白色正常,恩很诡异啊,原子你是用b505验证过了吗?
举报
更多回帖
