ti工程师,你们好:UDP客户端发送数据和接收数据中我使用了sl_Select去等待可发送和可接收事件,代码如下,但是出现的现象是写的sl_Select要等足8秒(我设置就为8秒)才返回,而读的sl_Select就一直都不返回,请问是我使用上存在问题还是其他什么原因呢?谢谢 SlTimeval_t sel_to; SlSockAddrIn_t ipas_addr; SlFdSet_t rfds, wfds; SlSockNonblocking_t enable_option; int i_addr_size, socket_fd = -1, ret; ipas_addr.sin_family = SL_AF_INET; ipas_addr.sin_port = sl_Htons(PORT); ipas_addr.sin_addr.s_addr = sl_Htonl(IP); i_addr_size = sizeof(SlSockAddrIn_t); socket_fd = sl_Socket(SL_AF_INET, SL_SOCK_DGRAM, 0); if(socket_fd < 0)[ DO_Printf("sl_Socket call Failure!rn"); goto function_exit; ] enable_option.NonblockingEnabled = 0x1; sl_SetSockOpt(socket_fd, SOL_SOCKET, SL_SO_NONBLOCKING, &enable_option, sizeof(enable_option)); keep_on_send: sel_to.tv_sec = 8; sel_to.tv_usec = 0; SL_FD_ZERO(&wfds); SL_FD_SET(socket_fd, &wfds); ret = sl_Select(socket_fd + 1, 0, &wfds, 0, &sel_to); if(ret < 0)[ DO_Printf("sl_Select1 call failure!rn"); goto function_exit; ]else[ if(SL_FD_ISSET(socket_fd, &wfds))[ ret = sl_SendTo(socket_fd, sp + already_len, willbe_len - already_len, 0, (SlSockAddr_t *)&ipas_addr, i_addr_size); if(ret < 0)[ DO_Printf("sl_SendTo call Failure!rn"); goto function_exit; ]else[ already_len += ret; DO_Printf("Send Data Count:%drn", already_len); if(already_len < willbe_len)[ goto keep_on_send; ] ] ]else[ DO_Printf("Send Data Timeout!rn"); goto function_exit; ] ] DO_Printf("Test Send Finishrn"); keep_on_recv: SL_FD_ZERO(&rfds); SL_FD_SET(socket_fd, &rfds); sel_to.tv_sec = 8; sel_to.tv_usec = 0; ret = sl_Select(socket_fd + 1, &rfds, 0, 0, &sel_to); if(ret < 0)[ DO_Printf("sl_Select2 call failure!rn"); goto function_exit; ]else[ if(SL_FD_ISSET(socket_fd, &rfds))[ ret = sl_RecvFrom(socket_fd, sp + already_len, willbe_len - already_len, 0, (SlSockAddr_t *)(&ipas_addr), (SlSocklen_t*)(&i_addr_size)); if(ret < 0)[ if(ret == SL_EAGAIN)[ goto keep_on_recv; ] DO_Printf("sll_SendTo call Failure!rn"); goto function_exit; ]else[ already_len += ret; if(already_len < willbe_len)[ goto keep_on_recv; ] ] ]else[ DO_Printf("Recv Data Timeout!rn"); goto function_exit; ] ] .....
