TI论坛
直播中
丛聪
8年用户 286经验值
私信 关注
[问答]
DM8168 H.264编码没有数据输出
软件环境 : DVRRDK_04.00.00.03
硬件环境 : DM8168, 一路PAL信号输入,需要对PAL信号进行H.264 baseline profile 进行编码,存储成文件,或者网络发送。
问题1 :
Cap(YUV420SP_UV) -> Dup -> swMs -> Dis
                                             --> ipcOutVpss -> ipcInVideo -> Enc -> iPCBitsOutVideo -> ipcBitsInHost -> wirte file
在上面的这种链路下,如何H.264的格式为 high profile 和 main profile时, 可以输出显示,并且能生成H.264文件,
生成的文件可以用VLC播放。
但是,如果见profile 改成 baseline profile 运行是就会报错,错误信息如下:
[m3vpss ] 22018: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 22019: IPC_OUT_M3 : Create Done !!!
[m3video] 22037: ENCODE: Creating CH0 of 720 x 288, pitch = (736, 736) [INTERLACED ] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] 22048:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[232]::INTERNAL ERROR:-1
[m3video] ALGCONTROL FAILED:CMD:6
[m3video] ERROR: IH264ENC_PROFILE_INCOMPLAINT_CONTENTTYPE = 1,
[m3video] ERROR: XDM_UNSUPPORTEDPARAM = 14,
[m3video] ERROR: XDM_FATALERROR = 15
[m3video] 22049:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[232]::INTERNAL ERROR:-1
[m3video] ALGCONTROL FAILED:CMD:3
[m3video]
[m3video] 22049:ERR::linkID:10000021::channelID:0::errorCode:-5::FileName:links_m3video/iva_enc/encLink_h264.c::linuNum:1276::errorCondition:(algStatus == XDM_EOK)
[m3video] ENCLINK_H264:HEAPID:0 USED:1896
[m3video] 22050: Assertion @ Line: 949 in links_m3video/iva_enc/encLink_common.c: retVal == ENC_LINK_S_SUCCESS : failed !!
问题2 :
针对问题1的情况,和查阅的相关资料,baseline profile 不支持interlace信号的编码(high 和 main 支持),于是改变了link连接如下:
Cap(YUV422I_YUYV) -> Nsf -> DEIH -> swMs -> Dis
                                                            --> ipcOutVpss -> ipcInVideo -> Enc -> ipcBitsOutVideo -> ipcBitsInHost -> wirte file
其中DEI设置如下:
deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC] = TRUE;
deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC] = TRUE;
deiPrm.comprEnable = FALSE;
deiPrm.setVipScYuv422Format = FALSE;
deiPrm.enableDeiForceBypass = FALSE;
deiPrm.enableLineSkipSc = FALSE;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].scaleMode = DEI_SCALE_MODE_ABSOLUTE;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].absoluteResolution.outWidth = 720;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].absoluteResolution.outHeight = 576;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_ABSOLUTE;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].absoluteResolution.outWidth = 720;
deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].absoluteResolution.outHeight = 576;
deiPrm.outQueParams[DEI_LINK_OUT_QUE_DEI_SC].nextLink = gVdisModuleContext.swMsId[0];
deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink = ipcOutVpssId;
希望DEIH的一路输出 DEI_SC 为 YUV422I 用于显示,另一路输出 VIP_SC 为YUV420SP 用于编码。
程序运行的时候出错,错误信息如下:
[m3vpss ] 20841: DEI : Create Done !!!
[m3vpss ] 20841: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 20842: IPC_OUT_M3 : Create Done !!!
[m3video] 20861: ENCODE: Creating CH0 of 720 x 576, pitch = (1440, 1440) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] 20861: Assertion @ Line: 759 in links_m3video/iva_enc/encLink_common.c: pChAlgCreatePrm->inputChromaFormat == XDM_YUV_420SP : failed !!!
后来自己做了一个测试,发现如果 DEI_SC 和 VIP_SC 同时使能输出的话,传给ipcOutVpssId实际是DEI_SC的数据而不是 VIP_SC 的数据。
问题3 :
针对问题2存在的问题,再一次修改link链接,如下:
Cap(YUV422I_YUYV) -> Dup -> swMs -> Dis
                                            Nsf -> DEIH(VIP_SC) --> ipcOutVpss -> ipcInVideo -> Enc -> ipcBitsOutVideo -> ipcBitsInHost -> wirte file
这样在DEIH中禁止DEI_SC输出,使能VIP_SC输出,如下:
修改之后,运行没有问题,能够显示输出,但是编码没有数据输出:
附件中是我的程序源码,以及针对问题3,调试串口打印的输出信息。
希望能够帮忙分析一下,给我一点建议,我现在调的没有头绪,呵呵。 附件中是的我程序源码和log。
回帖(16)
葛睿洁
2020-4-15 07:28:27
你好;
问题描述挺详细的;
问题1,问题2,问题你已经解决了
在问题3中,通过下面打印log信息可以分析出
编码器没有编码,dei的数据全部跳帧了,也就dei模块的数据没有输出
举报
葛睿洁
2020-4-15 07:34:51
你问题3中的打印信息里面怎么有2个dei模块出来了呢,代码里面只启动了1个dei模块
[m3vpss ]   [m3vpss ]  *** [DEI0    ] DEI Statistics ***  [m3vpss ]   [m3vpss ]  Elasped Time           : 101 secs [m3vpss ]  Total Fields Processed : 6009  [m3vpss ]  Total Fields FPS       : 500 FPS [m3vpss ]   [m3vpss ]   [m3vpss ]  CH  | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency    [m3vpss ]  Num | FPS     FPS       FPS        FPS    FPS    FPS    FPS    FPS       FPS         FPS         FPS         FPS         FPS       Skip FPS    Skip FPS    Skip FPS    Skip FPS    Skip FPS   Min / Max  [m3vpss ]  ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ]    0 |      59         0         59     29      0      0      0      0           0          59           0           0           0          29           0           0           0           0  10 /  27 [m3vpss ]   [m3vpss ]   [m3vpss ]  *** [DEI2    ] DEI Statistics ***  [m3vpss ]   [m3vpss ]  Elasped Time           : 101 secs [m3vpss ]  Total Fields Processed : 6009  [m3vpss ]  Total Fields FPS       : 500 FPS [m3vpss ]   [m3vpss ]   [m3vpss ]  CH  | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency    [m3vpss ]  Num | FPS     FPS       FPS        FPS    FPS    FPS    FPS    FPS       FPS         FPS         FPS         FPS         FPS       Skip FPS    Skip FPS    Skip FPS    Skip FPS    Skip FPS   Min / Max  [m3vpss ]  ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ]    0 |      59         0         59      0     59      0      0      0          59           0           0           0           0           0           0           0           0           0  11 /  27 [m3vpss ]   [m3vpss ]
举报
丛聪
2020-4-15 07:40:47
[m3vpss ]   [m3vpss ]  *** [DEI0    ] DEI Statistics ***  [m3vpss ]   [m3vpss ]  Elasped Time           : 101 secs [m3vpss ]  Total Fields Processed : 6009  [m3vpss ]  Total Fields FPS       : 500 FPS [m3vpss ]   [m3vpss ]  ...
对于问题3 昨天的log有点问题,今天我重新打印了log信息,从log信息看DEI
[m3vpss ]
[m3vpss ] Elasped Time : 8 secs
[m3vpss ] Total Fields Processed : 379
[m3vpss ] Total Fields FPS : 505 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 47 0 47 0 47 0 0 0 47 0 0 0 0 0 0 0 0 0 15 / 27
[m3vpss ]
我现在用的是DEIH VIP_SC ,DEI_SC禁止,从上面的信息看Out[1] FPS 的为49 ,Skip Out[0] FPS 为 47,现在是不是正常?
同时我还打印了ENC的信息:
[m3video] *** Encode Statistics ***
[m3video] 114196: ENC: Rcvd from prev = 4542, Returned to prev = 4542
[m3video] ENC Out BitBuf Q Status
[m3video] Full Q -> count 0, wrPtr 0, rdPtr 0
从上面看ENC是不是有数据收到? Rcvd from prev = 4542, Returned to prev = 4542
请分析一下,谢谢。
怎么不能上传附件呢?
U-Boot 2010.06 (Jun 03 2015 - 14:07:50)
TI8168-GP rev 2.1
HDVICP clk : 600MHz
L3 Fast clk : 520MHz
HDVPSS clk : 260MHz
Ducati M3 clk : 260MHz
DSP clk : 1000MHz
ARM clk : 987MHz
DDR clk : 675MHz
I2C: ready
DRAM: 2 GiB
NAND: HW ECC BCH8 Selected
256 MiB
MMC: OMAP SD/MMC: 0
:,;;:;:;;;;;;;;r;;:,;;:;:;;;;;;;;:,;;:;:;;;;;;;;:,;;:;:;;;;;;;;:;;;;;;;;:,;;:;:
;,;:::;;;;r;;;rssiSiS552X5252525259GX2X9hX9X9XX2325S55252i5:,;;:;:;;;;;;;;:,;;:
;:;;;;;;;rrssSsS52S22h52299GGAAMHMM#BBH#B#HMM#HMBA&&XX2255S2S5Si:,;;:;:;;;;;;;;
;:;;r;;rsrrriiXS5S329&A&MH#BMB#A&9XXA252GXiSXX39AAMMMBB&G22S5i2SSiiiisi:,;;:;:;
;;;;;r;rr2iisiih393HB#B#AA99i22irrrX3X52AGsisss2Xii2299HBMA&X2S5S5iSiisSsi:,;;:
r:r;rrsrsihXSi2&##MHB&Ahh3AGHGA9G9h&#H##@@@##MAMMXXX9SSS29&&HGGX2i5iisiiisisi:,
;;rrrrsSiiiA&ABH&A9GAGhAhBAMHA9HM@@@@@@@@@@@@@@@@@@@HHhAh2S2SX9&Gh22SSiisiiisii
r:rrssisiS2XM##&h3AGAX&3GG3Ssr5H@M#HM2; ;2X&&&MHMB###GBB#B&XXSSs529XX55iSsisisi
r;rsrisSi2XHAhX99A3XXG&&XS;:,rH#HGhAS @@@@3rs2XBM@@A552&&AHA2XiisSS252SSsisSs
r;issi5S22&&3iSSX292&hXsr;;:;h@&G339&S9@@@@2@MA&9&HB##Xris29ABMAAX2ir;rsSi5iss5
rrsSi2XhG&9GXh399&X99i;;;;;;r#H&293H9X#@@@@@@@B&9GhAH@XrrsrsiXABHB&HG2rr;rrSiSi
;:rsisS599&AA9XG&3A35r;:::;,;BMh&&2iX5A@@@@@@@&392X5GB2;;;r;iSX393A##A&Xi:::rsi
;:rss552222X553&XHMhir;;::,:,h#HhGSXhG3#@@@@#AXXS2XAHA;::;;;;ss55XShBA3239r:,;;
r;ii2S5SSi2i53hirsh2srr::,,,,;MMXX359&Ah3h&Si59SX99A#i:,::::;;sri2,.2r;:SGAr;,:
;:;rrrrssiriXGSi::shs;;;,,,:,,rBBA9h5s5h5iS5isi2SAHB5:,,,:::;rrs5&SrisSX5Srrr:,
;,r;;;;rsriSSrrrr;;5Xrr;;,:,,.,;9AA2SsisS5323XXXG9&i:.,,::;;r;;;srrrrrr;;:;::::
:,;r;r;rrissrrr;:;::;s;;;;,:,,..,r293h222hXXAAGGGX;:,,,:,:,::;:;::,:,,,,...,,,,
;,;;;;rrrrrrrrirr;,.,,:::::::,,,,.,;SX&ABAB2hhXir:,,.,,.,,:,,,,..,,,..,..,,,..:
:.:;:;;;:;;;;r;rrs;:.. ,,:::::,:,:,,.::rrsrr;;,,.......,..,....,,,,,,,...,.,,:,
:.:::,::::::;;r;rrr;:.......,.,.,,:::,,...............,,::.,,,,:,::,,:,:,,,:,;:
,.::,:,,,,,;;;;;;;;r;;::,..............................;;;:;::::,:::::::,:,:,,,
: ,,:,,,,,,,,,,,,,:;rrr;;:;,,,,,,,::,.,.:.,.,;s,:;;;;:;:;;;;;::::,:::,:::,:,:,:
Net: Detected MACID:78:a5:4:e5:28:ea
Ethernet PHY: GENERIC @ 0x01
DaVinci EMAC
Hit any key to stop autoboot: 0
Loading from NAND 256MiB 3,3V 8-bit, offset 0x580000
Image Name: Linux-2.6.37-2.0.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2689524 Bytes = 2.6 MiB
Load Address: c0008000
Entry Point: c0008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37-2.0.0 (chyb@chyb-machine) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Wed Jun 3 14:18:38 CST 2015
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8168etv
vram size = 52428800 at 0x0
ti81xx_reserve: ### Reserved DDR region @dff00000
reserved size = 52428800 at 0x0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8168 2.1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 116992
Kernel command line: mem=512M ddr_mem=2048M console=ttyO0,115200n8 ubi.mtd=4,2048 root=ubi0:rootfs rootwait rootfstype=ubifs rw ip=192.168.1.201:192.168.1.202:192.168.1.1:255.255.255.0::eth0:off vram=50M vmalloc=476M notifyk.vpssm3_sva=0xBFB00000
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 460MB 1MB = 461MB total
Memory: 461756k/461756k available, 62532k reserved, 41984K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xda800000 - 0xf8000000 ( 472 MB)
lowmem : 0xc0000000 - 0xda400000 ( 420 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0041000 ( 228 kB)
.text : 0xc0041000 - 0xc051c000 (4972 kB)
.data : 0xc051c000 - 0xc0567bc0 ( 303 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 27000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0xdff00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 0
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
Cannot clk_get ck_32
pm_dbg_init: only OMAP3 supported
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xda820000
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
ti81xx_pcie: PCI scan done.
bio: create slab at 0
vgaarb: loaded
SCSI subsystem initialized
u***core: registered new interface driver u***fs
u***core: registered new interface driver hub
u***core: registered new device driver u***
USBSS revision 4ea20809
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
mu***-hdrc: version 6.0, host, debug=0
mu***-hdrc mu***-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver
mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1
u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002
u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
u*** u***1: Product: MUSB HDRC host driver
u*** u***1: Manufacturer: Linux 2.6.37-2.0.0 mu***-hcd
u*** u***1: SerialNumber: mu***-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mu***-hdrc mu***-hdrc.0: USB Host mode controller at da81e000 using DMA, IRQ 18
mu***-hdrc mu***-hdrc.1: dma type: dma-cppi41
MUSB controller-1 revision 4ea20800
mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver
mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2
u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002
u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
u*** u***2: Product: MUSB HDRC host driver
u*** u***2: Manufacturer: Linux 2.6.37-2.0.0 mu***-hcd
u*** u***2: SerialNumber: mu***-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mu***-hdrc mu***-hdrc.1: USB Host mode controller at da826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 819
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
register mise_device success
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
brd: module loaded
loop: module loaded
ahci probe: devid name is ahci
ahci CAP register dump =0x6726ff81
Modified ahci CAP register dump =0x6f26ff81
ahci ahci.0: forcing PORTS_IMPL to 0x3
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
omap2-nand driver initializing
NAND device: Maf ID: 0xec, Chip ID: 0xda (Samsung, )
erasesize: 0x20000, writesize: 2048, oobsize: 64
omap2-nand: detected x8 NAND flash
Creating 5 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000580000 : "U-Boot Logo"
0x000000580000-0x0000009c0000 : "Kernel"
0x0000009c0000-0x000010000000 : "File System"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
UBI: max. sequence number: 1726
UBI: attached mtd4 to ubi0
UBI: MTD device name: "File System"
UBI: MTD device size: 246 MiB
UBI: number of good PEBs: 1968
UBI: number of bad PEBs: 2
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 1968
UBI: number of PEBs reserved for bad PEB handling: 38
UBI: max/mean erase counter: 3/1
UBI: image sequence number: 1332541801
UBI: background thread "ubi_bgt0d" started, PID 42
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffff9
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver ET1011C
davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver ET1011C
u***core: registered new interface driver cdc_ether
u***core: registered new interface driver dm9601
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
u***core: registered new interface driver cdc_wdm
Initializing USB Mass Storage driver...
u***core: registered new interface driver u***-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
rtc-x1226 1-006f: x1226_validate_client: could not read register 3f
rtc-x1226 1-006f: Failed to validate device.
i2c /dev entries driver
Linux video capture interface: v2.00
u***core: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
u***core: registered new interface driver u***hid
u***hid: USB HID core driver
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfb00000
u***core: registered new interface driver snd-u***-audio
u***core: registered new interface driver snd-ua101
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI81XX ETV SOUND0
#1: TI81XX ETV SOUND1
nf_conntrack version 0.5.0 (7214 buckets, 28856 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
drivers/rtc/hctosys.c: unable to open rtc device (rtc1)
davinci_mdio davinci_mdio.0: resetting idled controller
net eth0: attached PHY driver [ET1011C] (mii_bus:phy_addr=0:01, id=282f014)
IP-Config: Complete:
device=eth0, addr=192.168.1.201, mask=255.255.255.0, gw=192.168.1.1,
host=192.168.1.201, domain=, nis-domain=(none),
bootserver=192.168.1.202, rootserver=192.168.1.202, rootpath=
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 199225344 bytes (194556 KiB, 189 MiB, 1569 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:15.
devtmpfs: mounted
Freeing init memory: 228K
INIT: version 2.88 booting
Mounting /dev/shm :
Mounting /dev/pts :
Mounting other filesystems :
Sync command ...
Error opening /dev/fb0: No such file or directory
Starting udev
udev[72]: starting version 164
Starting Bootlog daemon: PHY: 0:01 - Link is Up - 1000/Full
bootlogd.
Applying sync command
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyO0
Arago 2012.10 ti81xx ttyO0
ti81xx login: root
root@ti81xx:~# ls
demo.sh nfs_mount.sh opt
root@ti81xx:~# ./nfs_mount.sh
NFS mount OK!
root@ti81xx:~# ls
root@ti81xx:~# cd opt/dvr_rdk/ti816x/
root@ti81xx:~/opt/dvr_rdk/ti816x# ls
bin init.sh rotate_logs.sh run_link_api.sh
demo_ini kermod rtsp_client scripts
env_1024M_256M.sh load.sh rtsp_server store_logs.sh
env_2048M_512M.sh open_bin run.sh unload.sh
firmware parseEnv.sh run_gui.sh validate.sh
root@ti81xx:~/opt/dvr_rdk/ti816x# ./init.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
*** Kernel Base address validated ***
Kernel bootargs validated
SysLink version : 2.20.02.20
SysLink module created on Date:Jun 17 2015 Time:11:14:24
Trace enabled
Trace SetFailureReason enabled
[c6xdsp ] Remote Debug Shared Memory @ 0xbfd00000
[m3video] Remote Debug Shared Memory @ 0xbfd10820
[m3vpss ] Remote Debug Shared Memory @ 0xbfd21040
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
/home/root/opt/dvr_rdk/ti816x
root@ti81xx:~/opt/dvr_rdk/ti816x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_2048M_512M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** VPSS Firmware build time 11:28:04 Jun 17 2015 EDG gcc 3.0 mode
[m3vpss ] ***** SYSTEM : Frequency - 250000000, - 260000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 520000 Khz ***
[m3vpss ]
[m3vpss ] 37: SYSTEM : System Common Init in progress !!!
[m3vpss ] 37: SYSTEM: IPC init in progress !!!
[m3vpss ] 37: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 40: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_2048M_512M.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** VIDEO Firmware build time 11:28:59 Jun 17 2015 EDG gcc 3.0 mode
[m3video] ***** SYSTEM : Frequency - 250000000, - 260000000
[m3video]
[m3video] *** UTILS: CPU KHz = 520000 Khz ***
[m3video]
[m3video] 375: SYSTEM : System Common Init in progress !!!
[m3video] 375: SYSTEM: IPC init in progress !!!
[m3video] 375: SYSTEM: Attaching to [HOST] ...
[m3video] 379: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_2048M_512M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** VIDEO Firmware build time 11:26:29 Jun 17 2015 EDG gcc 3.0 mode
[c6xdsp ] ***** SYSTEM : Frequency - 800000000, - 1000000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 1000000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 8: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 10: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 659: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 660: SYSTEM: Attaching to [DSP] .DMA: Module install successful, device major num = 250
.. SUCCESS !!!
DRV: Module install successful
[c6xdsp ] 12: DRV: Module built on Jun 17 2015 11:14:56
SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3video] 662: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 662: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 12: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
[m3video] 663: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
[m3vpss ] 663: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
[c6xdsp ] 12: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 663: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 663: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[c6xdsp ] 12: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 663: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 663: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ] 12: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 665: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 665: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3video] 665: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 665: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3video] 665: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 665: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: IPC init DONE !!!
[m3video] 665: SYSTEM: IPC init DONE !!!
[m3vpss ] 665: SYSTEM: IPC init DONE !!!
[c6xdsp ] 14: MEM: Shared Region 2: Base = 0x96000000, Length = 0x28000000 (640 MB)
[c6xdsp ] 14: MEM: ERROR: SharedRegion_setEntry (2, 0x955dc79c) FAILED !!! (status=-1)
[m3video] 671: MEM: Shared Region 2: Base = 0x96000000, Length = 0x28000000 (640 MB)
[m3vpss ] 671: MEM: Shared Region 2: Base = 0x96000000, Length = 0x28000000 (640 MB)
[m3video] 671: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[m3vpss ] 671: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[m3video] 673: SYSTEM : System Common Init Done !!!
[m3vpss ] 673: SYSTEM : System Common Init Done !!!
[m3video] 673: SYSTEM : System Video Init in progress !!!
[m3vpss ] 673: SYSTEM : System VPSS Init in progress !!!
[m3video] 673: SYSTEM : System Video Init Done !!!
[m3video] 674: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 674: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 674: SYSTEM: ListElem Shared Addr = 0xbe1b3e00
[m3video] 677: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 677: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 677: SYSTEM: ListElem Shared Addr = 0xbe1b7300
[m3video] 683: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3vpss ] === HDVPSS Clocks are enabled ===
[m3video] 683: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3vpss ] === HDVPSS is fully functional ===
[m3video] 684: SYSTEM: ListElem Shared Addr = 0xbe1bdd00
[m3vpss ] === HDVPSS module is not in standby ===
[m3video] 686: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3vpss ] === I2C1 Clk is active ===
[m3video] 686: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_0
[m3video] 687: SYSTEM: ListElem Shared Addr = 0xbe1e6a00
[m3vpss ] 683: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 689: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] 683: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 683: SYSTEM: ListElem Shared Addr = 0xbe1bab00
[m3video] 689: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 686: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 689: SYSTEM: ListElem Shared Addr = 0xbe20c200
[m3vpss ] 686: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 704: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 686: SYSTEM: ListElem Shared Addr = 0xbe1e3500
[m3video] 704: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 701: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[m3video] 704: SYSTEM: ListElem Shared Addr = 0xbe257780
[m3vpss ] 701: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[m3video] 706: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 701: SYSTEM: ListElem Shared Addr = 0xbe231a00
[m3video] 707: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 704: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[m3video] 707: SYSTEM: ListElem Shared Addr = 0xbe29a780
[m3vpss ] 704: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 709: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 704: SYSTEM: ListElem Shared Addr = 0xbe274d00
[m3video] 709: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 707: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 709: HDVICP: Doing PRCM for IVAHD[1] ...
[m3vpss ] 707: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[m3video] 709: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3vpss ] 707: SYSTEM: ListElem Shared Addr = 0xbe2b8000
[m3video] 709: HDVICP: Doing PRCM for IVAHD[2] ...
[m3vpss ] 709: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 709: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3vpss ] 709: SYSTEM : FVID2 Init in progress !!!
[m3video] 710: SYSTEM : Initializing Links !!!
[m3vpss ] Received character 's'
[m3video] 710: SYSTEM : FREE SPACE : System Heap = 6279304 B, Mbx = 10240 msgs)
[m3video] Received character 's'
[m3video] 710: SYSTEM : FREE SPACE : SR0 Heap = 21114368 B (20 MB)
[m3vpss ] TILER_STATS: CNT :8BIT
[m3video] 710: SYSTEM : FREE SPACE : Frame Buffer = 671088512 B (639 MB)
[m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 8192
[m3video] 710: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
[m3video] 710: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 1
[m3video] 712: SYSTEM : FREE SPACE : Tiler 8-bit = 134152192 B (127 MB) - TILER ON
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 0
[m3video] 712: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 134152192 (99 %)
[m3video] 749: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] TILER_STATS: TOTAL USED AREA: 0 (0 %)
[m3vpss ] TILER_STATS: CNT :16BIT
[m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 4096
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 4096
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 134217728 (100 %)
[m3vpss ] 782: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 782: SYSTEM : Device Init in progress !!!
[m3vpss ] 785: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 827: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 828: UTILS: DMA: HWI Create for INT63 !!!
[m3vpss ] 829: SYSTEM : Initializing Links !!!
[m3vpss ] 829: SYSTEM : FREE SPACE : System Heap = 74056 B, Mbx = 10240 msgs)
[m3vpss ] 829: SYSTEM : FREE SPACE : SR0 Heap = 21114368 B (20 MB)
[m3vpss ] 829: SYSTEM : FREE SPACE : Frame Buffer = 666778496 B (635 MB)
[m3vpss ] 829: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 830: SYSTEM : FREE SPACE : Tiler 8-bit = 134152192 B (127 MB) - TILER ON
[m3vpss ] 830: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 953: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 953: SYSTEM : Set Static L3 pressure for HDVPSS as High
[c6xdsp ] 1020: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[c6xdsp ] 1021: SYSTEM : System Common Init Done !!!
[c6xdsp ] 1008: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 1008: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[c6xdsp ] 1023: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[c6xdsp ] 1023: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[c6xdsp ] 1023: SYSTEM: ListElem Shared Addr = 0xbe2dd800
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[c6xdsp ] 1024: SYSTEM: ListElem Shared Addr = 0xbe303000
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
[c6xdsp ] 1025: SYSTEM: Creating ListMP[module] vpss probe done.
[DSP_IPC_IN_21] in region 0 ...
[c6xdsp ] 1025: SYSTEM: ListElem Shared Addr = 0xbe328800
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 1025: SYSTEM: ListElem Shared Addr = 0xbe34e000
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 1026:[module] ti81xxfb probe done.
SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 1026: SYSTEM: ListElem Shared Addr = 0xbe36bb00
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 1014: SYSTEM : Initializing Links !!!
[c6xdsp ] Received character 's'
[c6xdsp ] 1026: SYSTEM : FREE SPACE : SysteHDMI W1 rev 2.0
m Heap = 10HDMI CEC Spec version 1.2
391168 B, Mbx = 10240 msgs)
[c6xdsp ] 1023: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] ETH_OFFLOAD: Init !!!
[c6xdsp ] 1023: SYSTEM : System DSP Init Done !!!
ORG 0x46c00524: 0
NEW 0x46c00524: 2
root@ti81xx:~/opt/dvr_rdk/ti816x# cd bin
root@ti81xx:~/opt/dvr_rdk/ti816x/bin# ls
dvr_rdk_demo_link_api.out i2c_rdwr.out remote_debug_client.out
dvr_rdk_demo_mcfw_api.out mem_rdwr.out sys_pri.out
dvrmain mem_stats.out vpdma_dump.out
fw_load.out pll_print.out
root@ti81xx:~/opt/dvr_rdk/ti816x/bin# ./dvr_rdk_demo_mcfw_api.out
Program for HY-2041
Input port : VIP0_PORTA_720x576i, VIP0_PORTB_720x576i
1: VCAP + VDIS - No Encode or Decode - SWMS
2: VCAP + VENC + VDIS - Encode and Store - SWMS
3: VDEC + VDIS - Decode and Display - SWMS
e: Exit
Enter Choice: 2
0: SYSTEM: System Common Init in progress !!!
1: SYSTEM: IPC init in progress !!!
17: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
18: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
18: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
18: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
18: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
20: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
22: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
24: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
25: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
25: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
26: SYSTEM: Notify register to [DSP] line 0, event 15 ...
27: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
28: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
28: SYSTEM: IPC init DONE !!!
30: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
32: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
33: SYSTEM: ListElem Shared Addr = 0x40787880
34: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
37: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
38: SYSTEM: ListElem Shared Addr = 0x407bca80
40: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
42: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
44: SYSTEM: ListElem Shared Addr = 0x407f1c80
45: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
47: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
49: SYSTEM: ListElem Shared Addr = 0x40834f80
50: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
52: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
54: SYSTEM: ListElem Shared Addr = 0x40878280
71: SYSTEM: System Common Init Done !!!
[host] HDMI Ctrl :Initializing
[host] HDMI Ctrl :Initialized
[host] HDMI Ctrl :Sink Connected
Enable file write (YES - y / NO - n) : y
File write ENABLED !!!
Enter file write path : /mnt/
Selected file write path [/mnt/]
Select File Write CH ID [0 .. 0] : 0
Selected CH ID = 0
Opened file [/mnt//VID_CH00.h264] for writing CH0
Wait for sem...
[m3vpss ] 22637: CAPTURE: Create in progress !!!
[m3vpss ] 22670: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Non-mux Embedded Sync] !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[m3vpss ] CAPTURE::HEAPID:0 USED:328
[m3vpss ] CAPTURE::HEAPID:4 USED:11390976
[m3vpss ] 22705: CAPTURE: Create Done !!!
[m3vpss ] 22710: DUP : Create Done !!!
[m3vpss ] 22711: NSF: Create in progress !!!
[m3video] 22735: IPC_IN_M3 : Create in progress !!!
[m3video] 22735: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] NSF::HEAPID:0 USED:128
[m3video] 22735: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] NSF::HEAPID:4 USED:2225664
[m3vpss ] 22723: NSF: Create Done !!!
[m3vpss ] 22723: DEI : Create in progress !!!
[m3vpss ] 22733: DEI : Loading Up-scaling Co-effs
[m3vpss ] 22733: DEI : Co-effs Loading ... DONE !!!
[host] IpcBitsInLink_tskMain:Entered
[host] 7644: IPC_BITS_IN : Create in progress !!!
[host] 7644: IPC_BITS_IN : ListMPOpen start !!!
[host] 7644: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
[m3video] 22738: IPC_IN_M3 : Create Done !!!
[m3video] 22738: ENCODE: Create in progress ... !!!
[m3vpss ] DEI:HEAPID:0 USED:64
[m3video] 22741: ENCODE: All CH Create ... DONE !!!
[m3vpss ] DEI:HEAPID:1 USED:5216
[m3vpss ] DEI:HEAPID:4 USED:1456128
[m3vpss ] 22733: DEI : Create Done !!!
[m3video] ENCLINK:HEAPID:0 USED:120
[m3vpss ] 22734: IPC_OUT_M3 : Create in progress !!!
[m3video] 22743: ENCODE: Create ... DONE !!!
[m3vpss ] 22735: IPC_OUT_M3 : Create Done !!!
[m3video] 22743: IPC_BITS_OUT : Create in progress !!!
7647: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
[host] 7648: IPC_BITS_IN : ListMPOpen done !!!
[host] 7649: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 7649: IPC_BITS_IN : Create Done !!!
[m3vpss ] 22751: SWMS: Create in progress !!!
[m3video] 22745: IPC_BITS_OUT : Create Done !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 60 (0x49004780)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 67 (0x49004860)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 160 (0x49005400)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 161 (0x49005420)
[m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
[m3vpss ] 22861: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 22861: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 22861: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
[m3vpss ] 22862: SWMS : ******* Configuring clock 33 secs...
[m3vpss ] 22862: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 22862: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 22862: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] 0 | 0 | 0, 0 | 720 x 288 | 1472 / 1472 | NON-TILED | 0, 0 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 1 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 0 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 2 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 540 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 3 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 540 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ]
[m3vpss ] SWMS:HEAPID:0 USED:360
[m3vpss ] SWMS:HEAPID:1 USED:47296
[m3vpss ] SWMS:HEAPID:4 USED:20736000
[m3vpss ] 22864: SWMS: Create Done !!!
[m3vpss ] 22865: DISPLAY: Create in progress !!!
[m3vpss ] 22866: DISPLAY: Create Done !!!
[m3vpss ] 22866: DISPLAY: Start in progress !!!
[m3vpss ] 22909: DISPLAY: Start Done !!!
[m3vpss ] 22910: DISPLAY: HDDAC(BP0) : 46 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8259 / 0 ) !!!
[m3vpss ] 22910: SWMS: Start in Progress !!!
[m3vpss ] 22910: SWMS: Start Done !!!
[m3vpss ] 22910: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 22910: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 0
[m3vpss ] 22910: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10239 msgs)
[m3vpss ] 22910: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 22911: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 22911: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 0
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 1
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 131184640 (97 %)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 2967552 (2 %)
[m3vpss ] TILER_STATS: TOTAL WASTE AREA: 0 (0 %)
[m3vpss ] TILER_STATS: MAX WIDTH RECT: 16384 x 7612
[m3vpss ] TILER_STATS: MAX HEIGHT RECT: 16384 x 7612
[m3vpss ] TILER_STATS: RES ALLOC COUNT [D1] : 7
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 132733952 (98 %)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 1483776 (1 %)
[m3vpss ] TILER_STATS: MAX WIDTH RECT: 32768 x 3808
[m3vpss ] TILER_STATS: MAX HEIGHT RECT: 32768 x 3808
[m3vpss ] 22913: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 22913: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3vpss ] 23176: CAPTURE: Start in progress !!!
[m3vpss ] 23275: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 23283: CAPTURE: Start Done !!!
DEMO: HDMI TV/Monitor connected !!!
DEMO: TV Detected - HDMI interface !!!
DEMO: INFO : Resolution set to 1080P60 !!!
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
i: Print detailed system information
s: Core Status: Active/In-active
b: Print link buffers statistics
e: Stop Demo
Enter Choice: i
[m3vpss ]
[m3vpss ] *** Capture Driver Advanced Statistics ***
[m3vpss ]
[m3vpss ] VIP Parser Reset Count : 0
[m3vpss ]
[m3vpss ] | Total Even Odd Total Even Odd Min / Max Min / Max Dropped Fid Repeat Frame Error Y/C
[m3vpss ] CH | Fields Fields Fields FPS FPS FPS Width Height Fields Count (Desc Error Y/C)
[m3vpss ] 000 | 381 191 190 54 27 27 720 / 720 288 / 288 1 0 0/0 (0/0)
[m3vpss ]
[m3vpss ] VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[m3vpss ]
[m3vpss ] *** Capture List Manager Advanced Statistics ***
[m3vpss ]
[m3vpss ] List Post Count : 954
[m3vpss ] List Stall Count : 0
[m3vpss ] List Post Time (ms) : Max = 0, Min = 0, Avg = 0, Total = 0
[m3vpss ] INTC Timeout Count : (0, 0) (Min timeout value = 992, 1000)
[m3vpss ] Descriptor miss found count : 0
[m3vpss ]
[m3vpss ]
[m3vpss ] VIP and VPDMA registers,
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000
[m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00020000
[m3vpss ]
[m3vpss ]
[m3vpss ] 30912: CAPTURE: Fields = 380 (fps = 49, CPU Load = 0)
[m3vpss ] 30913: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 30913: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10239 msgs)
[m3vpss ] 30913: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 30913: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 30913: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 30915: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 30915: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3vpss ]
[m3vpss ] *** [NSF0] NSF Statistics ***
[m3vpss ]
[m3vpss ] Total Fields Processed : 380
[m3vpss ] Total Fields FPS : 1000 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Reject In Process Out User Out Out
[m3vpss ] Num | FPS FPS FPS FPS Skip FPS Skip FPS
[m3vpss ] 0 | 47 0 47 47 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 8 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 29 fps (238 frames)
[m3vpss ] Output Actual FPS : 29 fps (238 frames)
[m3vpss ] Output Drop FPS : 0 fps (0 frames)
[m3vpss ] Output Reject FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 33 ms
[m3vpss ] Scaling Internal min : 33 ms
[m3vpss ] Scaling Internal max : 34 ms
[m3vpss ]
[m3vpss ] Win | Window Repeat Drop Recv Que FID Invlid Acc Event Invalid Que Reject Reject Latency OutBufCopy InBufCopy
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS Count (Max/Min) CH Frames Frames Frames Min / Max FPS FPS
[m3vpss ] 0 | 28 6 0 23 23 23 0 ( 0/255) 0 0 0 18 / 58 6 0
[m3vpss ] 1 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 29 0
[m3vpss ] 2 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 29 0
[m3vpss ] 3 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 29 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 1 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 0 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON |
[m3vpss ] 2 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 540 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON |
[m3vpss ] 3 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 540 | 960 x 540 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ] 30922: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 66 / 84 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 66 ) !!!
[m3vpss ] 30922: DISPLAY DRV: HDDAC(BP0) : Q:[478] Display:[482], Repeat:[7], DQ:[474]
[m3vpss ] 30923: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 480, HDDAC(BP0) 960, DVO2(BP1) 960, SDDAC(SEC1) 960
[m3vpss ] 30923: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10239 msgs)
[m3vpss ] 30923: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 30923: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 30923: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 30925: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 30925: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3video] 36926: HDVICP-ID:0
[m3video] All percentage figures are based off totalElapsedTime
[m3video] totalAcquire2wait :0 %
[m3video] totalWait2Isr :0 %
[m3video] totalIsr2Done :0 %
[m3video] totalWait2Done :0 %
[m3video] totalDone2Release :0 %
[m3video] totalAcquire2Release :0 %
[m3video] totalAcq2acqDelay :0 %
[m3video] totalElapsedTime in msec : 0
[m3video] numAccessCnt: 0
[m3video] IVA-FPS : 0
[m3video] Average time spent per frame in microsec: 0
[m3video] 36926: HDVICP-ID:1
[m3video] 36927: HDVICP-ID:2
[m3video]
[m3video] *** ENCODE Statistics ***
[m3video]
[m3video] Elasped Time : 36 secs
[m3video]
[m3video]
[m3video] CH | In Recv In Skip In User Out Latency
[m3video] Num | FPS FPS Skip FPS FPS Min / Max
[m3video] --------------------------------------------
[m3video]
[m3video] Multi Channel Encode Average Submit Batch Size
[m3video] Max Submit Batch Size : 24
[m3video] IVAHD_0 Average Batch Size : 0
[m3video] IVAHD_0 Max achieved Batch Size : 0
[m3video] IVAHD_1 Average Batch Size : 0
[m3video] IVAHD_1 Max achieved Batch Size : 0
[m3video] IVAHD_2 Average Batch Size : 0
[m3video] IVAHD_2 Max achieved Batch Size : 0
[m3video]
[m3video] Multi Channel Encode Batch break Stats
[m3video] Total Number of Batches created: 0
[m3video] All numbers are based off total number of Batches created
[m3video] Batch breaks due to batch sizeexceeding limit: 0 %
[m3video] Batch breaks due to ReqObj Que being empty: 0 %
[m3video] Batch breaks due to changed resolution class: 0 %
[m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
[m3video] Batch breaks due to channel repeat: 0 %
[m3video] Batch breaks due to different codec: 0 %
[m3vpss ]
[m3vpss ] 39931: LOAD: CPU: 8.8% HWI: 1.6%, SWI:1.0%
[m3vpss ]
[m3vpss ] 39931: LOAD: TSK: IPC_OUT_M30 : 0.4%
[m3vpss ] 39931: LOAD: TSK: CAPTURE : 0.7%
[m3vpss ] 39932: LOAD: TSK: NSF0 : 0.6%
[m3vpss ] 39932: LOAD: TSK: DEI0 : 1.0%
[m3vpss ] 39932: LOAD: TSK: DISPLAY0 : 0.4%
[m3vpss ] 39932: LOAD: TSK: DUP0 : 0.2%
[m3vpss ] 39932: LOAD: TSK: SWMS0 : 1.7%
[m3vpss ] 39932: LOAD: TSK: MISC : 1.2%
[m3vpss ]
[m3video]
[m3video] 40433: LOAD: CPU: 1.9% HWI: 0.3%, SWI:0.5%
[m3video]
[m3video] 40433: LOAD: TSK: IPC_IN_M30 : 0.2%
[m3video] 40433: LOAD: TSK: ENC0 : 0.6%
[m3video] 40433: LOAD: TSK: MISC : 0.3%
[m3video]
[c6xdsp ]
[c6xdsp ] 40285: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 40285: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
*** Encode Bitstream Received Statistics ***
Elased time = 18.2 secs
CH | Bitrate (Kbps) | FPS | Key-frame FPS | Width (max/min) | Height (max/min) | Latency (max/min)
[host]
*** SCD Frame Results Received Statistics ***
Elased time = 26.3 secs
CH | Bitrate (Kbps) | FPS | Width (max/min) | Height (max/min)
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice: b
[m3vpss ]
[m3vpss ] *** CAPTURE Statistics ***
[m3vpss ] 113691: CAPTURE: Queued to driver = 4533, Dequeued from driver = 4519
[m3vpss ] CAPTURE [0] Buf Q Status
[m3vpss ] Empty Q -> count 0, wrPtr 0, rdPtr 0
[m3vpss ] Full Q -> count 0, wrPtr 295, rdPtr 295
[m3vpss ]
[m3vpss ] 113691: NSF: Rcvd from prev = 4519, Returned to prev = 4519
[m3vpss ] NSF Out [0] Buf Q Status
[m3vpss ]
[m3vpss ] 113692: DEI: Rcvd from prev = 4519, Returned to prev = 4519
[m3vpss ] DEI Out [0] Buf Q Status
[m3vpss ] Full Q -> count 0, wrPtr 0, rdPtr 0
[m3vpss ] DEI Out [1] Buf Q Status
[m3vpss ] Full Q -> count 0, wrPtr 294, rdPtr 294
[m3vpss ] DEI Out [2] Buf Q Status
[m3vpss ] DEI Out [3] Buf Q Status
[m3vpss ] DEI Out [4] Buf Q Status
[m3vpss ]
[m3vpss ] 113695: SWMS: Rcvd from prev = 0, Returned to prev = 4518
[m3vpss ] SWMS Out Buf Q Status
[m3vpss ] Empty Q -> count 2, wrPtr 36, rdPtr 34
[m3vpss ] Full Q -> count 2, wrPtr 68, rdPtr 66
[m3vpss ]
[m3vpss ] *** Display Statistics ***
[m3vpss ] 113696: DISPLAY: Rcvd from prev = 5442, Returned to prev = 5439, BufsInDriver = 5
[m3video]
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice: i
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 000 | 5422 2711 2711 50 25 25 720 / 720 288 / 288 1 0 0/0 (0/0)
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] List Post Count : 13557
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 131733: CAPTURE: Fields = 5420 (fps = 49, CPU Load = 0)
[m3vpss ] 131733: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 131733: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10238 msgs)
[m3vpss ] 131733: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 131733: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 131733: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 131735: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 131735: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3vpss ]
[m3vpss ]
[m3vpss ] Elasped Time : 100 secs
[m3vpss ] Total Fields Processed : 5420
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 50 0 50 50 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] Total Fields Processed : 5419
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 50 0 50 0 50 0 0 0 50 0 0 0 0 0 0 0 0 0 12 / 28
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] Elasped Time: 100 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 30 fps (3025 frames)
[m3vpss ] Output Actual FPS : 30 fps (3025 frames)
[m3vpss ]
[m3vpss ] 0 | 30 5 0 25 25 25 0 ( 0/255) 0 0 0 15 / 61 5 0
[m3vpss ] 1 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 30 0
[m3vpss ] 2 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 30 0
[m3vpss ] 3 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 30 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 131743: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 66 / 84 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 66 ) !!!
[m3vpss ] 131743: DISPLAY DRV: HDDAC(BP0) : Q:[6528] Display:[6532], Repeat:[7], DQ:[6524]
[m3vpss ] 131743: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 6050, HDDAC(BP0) 12352, DVO2(BP1) 12352, SDDAC(SEC1) 12312
[m3vpss ] 131743: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10239 msgs)
[m3vpss ] 131744: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 131744: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 131744: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 131746: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 131746: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3video] 137746: HDVICP-ID:0
[m3video] 137747: HDVICP-ID:1
[m3video] 137748: HDVICP-ID:2
[m3video]
[m3video]
[m3video] Elasped Time : 100 secs
[m3video]
[m3video]
[m3video]
[m3video]
[m3vpss ]
[m3vpss ] 140752: LOAD: CPU: 7.8% HWI: 1.6%, SWI:1.0%
[m3vpss ]
[m3vpss ] 140752: LOAD: TSK: IPC_OUT_M30 : 0.4%
[m3vpss ] 140752: LOAD: TSK: CAPTURE : 0.3%
[m3vpss ] 140752: LOAD: TSK: NSF0 : 0.5%
[m3vpss ] 140752: LOAD: TSK: DEI0 : 0.9%
[m3vpss ] 140752: LOAD: TSK: DISPLAY0 : 0.4%
[m3vpss ] 140753: LOAD: TSK: DUP0 : 0.2%
[m3vpss ] 140753: LOAD: TSK: SWMS0 : 1.0%
[m3vpss ] 140753: LOAD: TSK: MISC : 1.5%
[m3vpss ]
[m3video]
[m3video] 141253: LOAD: CPU: 1.9% HWI: 0.3%, SWI:0.6%
[m3video]
[m3video] 141254: LOAD: TSK: IPC_IN_M30 : 0.2%
[m3video] 141254: LOAD: TSK: ENC0 : 0.5%
[m3video] 141254: LOAD: TSK: MISC : 0.3%
[m3video]
[c6xdsp ]
[c6xdsp ] 141106: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 141106: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
Elased time = 100.8 secs
[host]
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice: i
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 000 | 7318 3659 3659 50 25 25 720 / 720 288 / 288 1 0 0/0 (0/0)
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] List Post Count : 18297
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 169653: CAPTURE: Fields = 7316 (fps = 49, CPU Load = 0)
[m3vpss ] 169653: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 169653: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10238 msgs)
[m3vpss ] 169653: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 169653: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 169653: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 169655: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 169655: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3vpss ]
[m3vpss ]
[m3vpss ] Elasped Time : 37 secs
[m3vpss ] Total Fields Processed : 7316
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 51 0 51 51 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] Total Fields Processed : 7315
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 51 0 51 0 51 0 0 0 51 0 0 0 0 0 0 0 0 0 14 / 28
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] Elasped Time: 37 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 30 fps (1137 frames)
[m3vpss ] Output Actual FPS : 30 fps (1137 frames)
[m3vpss ]
[m3vpss ] 0 | 30 5 0 25 25 25 0 ( 0/255) 0 0 0 15 / 57 5 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 169663: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 66 / 84 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 49 / 66 ) !!!
[m3vpss ] 169664: DISPLAY DRV: HDDAC(BP0) : Q:[8802] Display:[8807], Repeat:[7], DQ:[8799]
[m3vpss ] 169664: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 2275, HDDAC(BP0) 4646, DVO2(BP1) 4646, SDDAC(SEC1) 4626
[m3vpss ] 169664: SYSTEM : FREE SPACE : System Heap = 67464 B, Mbx = 10239 msgs)
[m3vpss ] 169664: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 169664: SYSTEM : FREE SPACE : Frame Buffer = 630969728 B (601 MB)
[m3vpss ] 169664: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 169667: SYSTEM : FREE SPACE : Tiler 8-bit = 131184640 B (125 MB) - TILER ON
[m3vpss ] 169667: SYSTEM : FREE SPACE : Tiler 16-bit = 132733952 B (126 MB) - TILER ON
[m3video] 175667: HDVICP-ID:0
[m3video] 175668: HDVICP-ID:1
[m3video] 175669: HDVICP-ID:2
[m3video]
[m3video]
[m3video] Elasped Time : 37 secs
[m3video]
[m3video]
[m3video]
[m3video]
[m3vpss ]
[m3vpss ] 178673: LOAD: CPU: 7.8% HWI: 1.6%, SWI:1.0%
[m3vpss ]
[m3vpss ] 178673: LOAD: TSK: IPC_OUT_M30 : 0.4%
[m3vpss ] 178673: LOAD: TSK: CAPTURE : 0.3%
[m3vpss ] 178673: LOAD: TSK: NSF0 : 0.5%
[m3vpss ] 178673: LOAD: TSK: DEI0 : 0.9%
[m3vpss ] 178673: LOAD: TSK: DISPLAY0 : 0.4%
[m3vpss ] 178673: LOAD: TSK: DUP0 : 0.2%
[m3vpss ] 178673: LOAD: TSK: SWMS0 : 1.0%
[m3vpss ] 178673: LOAD: TSK: MISC : 1.5%
[m3vpss ]
[m3video]
[m3video] 179174: LOAD: CPU: 1.9% HWI: 0.3%, SWI:0.6%
[m3video]
[m3video] 179174: LOAD: TSK: IPC_IN_M30 : 0.2%
[m3video] 179174: LOAD: TSK: ENC0 : 0.6%
[m3video] 179174: LOAD: TSK: MISC : 0.2%
[m3video]
[c6xdsp ]
[c6xdsp ] 179026: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 179026: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
Elased time = 37.9 secs
[host]
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice: b
[m3vpss ]
[m3vpss ] 236941: CAPTURE: Queued to driver = 10696, Dequeued from driver = 10681
[m3vpss ] Full Q -> count 0, wrPtr 313, rdPtr 313
[m3vpss ]
[m3vpss ] 236941: NSF: Rcvd from prev = 10681, Returned to prev = 10681
[m3vpss ]
[m3vpss ] 236941: DEI: Rcvd from prev = 10681, Returned to prev = 10681
[m3vpss ] Full Q -> count 0, wrPtr 312, rdPtr 312
[m3vpss ]
[m3vpss ] 236943: SWMS: Rcvd from prev = 0, Returned to prev = 10680
[m3vpss ] Empty Q -> count 2, wrPtr 277, rdPtr 275
[m3vpss ] Full Q -> count 2, wrPtr 166, rdPtr 164
[m3vpss ]
[m3vpss ] 236943: DISPLAY: Rcvd from prev = 12838, Returned to prev = 12834, BufsInDriver = 6
[m3video]
[m3video] 237444: ENC: Rcvd from prev = 10704, Returned to prev = 10704
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice:
举报
葛睿洁
2020-4-15 08:00:17
通过上面的打印信息,dei0模块正常工作的;
但是hdvicp确实是没有工作;
没有编码,你可以继续跟代码,在mcfw中bios6的相关的代码,确定出现问题的具体位置
举报
更多回帖
