是德科技
直播中
冯润生
8年用户 153经验值
私信 关注
[问答]
怎么使用IVI-COM驱动程序进行N1996通道功率测量
我正在尝试使用Vee执行一系列自动通道功率测量来控制N1996 CSA。
我可以使用agilentCSAClass.ChannelPower类配置仪器并进行测量,但是我看不到从仪器返回实际通道功率测量值的方法 - 显示在屏幕左下方的数字表示通道功率
在我配置的集成带宽上。
我不想要整个迹线,峰值或类似的东西,我只需要一个通道功率测量。
如何从仪器中读回来?
以上来自于谷歌翻译
     以下为原文
  I'm trying to perform a series of automated channel power measurements using Vee to control a N1996 CSA. I can configure the instrument and make the measurement using the agilentCSAClass.ChannelPower class but I can't see a way to get the actual channel power measurement back from the instrument - the number that's displayed in the lower left of the screen representing the channel power over the integration bandwidth I've configured. I don't want  the whole trace, peak, or anything like that, I just need the one channel power measurement. How can I read this back from the instrument?
回帖(1)
韩凤英
2019-10-22 08:32:51
您好Clive,我们已经使用N1996 CSA在VEE中测试了IVI-COM驱动程序。
奇怪的是,我们没有找到回读测量结果的方法。
与通道功率测量相比,有一种方法可以在OBW测量中读取结果。
似乎驱动程序设计者在此驱动程序中忽略了此命令。
或者,您可以选择直接在VEE中发送SCPI命令。
最诚挚的问候西蒙
以上来自于谷歌翻译
     以下为原文
  Hi Clive,
We have tested the IVI-COM driver in VEE with N1996 CSA. It is weird we did not found out the way to read the measurement result back. Compared with channel power measurement,there is a way to read the result out in OBW measurement. It seems the driver designer ignored this command in this driver.
Alternatively, you can choose to send the SCPI command directly in VEE.
Best Regards
Simon
举报
更多回帖
