您好,我在使用VEE 7.03中的ActiveX Automation文件夹中的任何Excelexamplesfound时遇到以下错误消息:空指针问题错误= [0x80040204]我应该指出错误不会在程序第一次运行时发生,但是
,后续运行总是导致错误。
不幸的是,我无法在配置相同的其他PC上复制问题。
(VEE 7.03,Win XP Pro,MSExcel 2003)AddingShawn的KillProcess到Excel示例修正了问题PC上的错误。
任何想法可能是什么问题以及如何解决它?
谢谢,Tony我们会走低吗?
查看Yahoo!
信使的PC电话费率较低.---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”
单词订阅在邮件正文中。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。
如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。
以上来自于谷歌翻译
以下为原文
Hello, I am encountering the following error message while using any of the Excel examples found in the ActiveX Automation folder in VEE 7.03: Null Pointer Problem Error =[0x80040204] I should point out that the error does NOT occur on the very first time the program is run, however, subsequent runs always result in the error. Unfortunately, I have not been able to duplicate the problem on other PCs that are configured identically. (VEE 7.03, Win XP Pro, MS Excel 2003) Adding Shawn's KillProcess to the Excel example corrects the error on the problem PC. Any ideas what this problem might be and how to resolve it? Thanks, Tony
How low will we go? Check out Yahoo! Messengers low PC-to-Phone call rates.
You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]
To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email "vrf@agilent.com".
If you need help with the mailing list send a message to
"owner-vrf@it.lists.it.agilent.com".
Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
,后续运行总是导致错误。
任何想法可能是什么问题以及如何解决它?
谢谢,Tony我们会走低吗?
查看Yahoo!
以上来自于谷歌翻译
以下为原文
举报
