是德科技
直播中
高文军
8年用户 184经验值
私信 关注
[问答]
GPIB命令读取直流电源的最大额定值
大家好,我想知道是否有GPIB查询命令让我知道以下直流电源的最大电压和电流额定值?
我在手册中搜索没有运气你的帮助将非常感谢。
E5280 / E5281B,N57xx,662xA问候,Ajay
以上来自于谷歌翻译
     以下为原文
  Hi all,
I would like to know if there are a GPIB query command that would let me know the max voltage and current ratings of the following DC supplies? I searched in the manuals with no luck Your help would be highly appreciated.
E5280/E5281B, N57xx, 662xA
Regards,
Ajay
回帖(3)
罗敏
2019-9-29 09:12:38
嗨,Ajay,我不熟悉你提到的第一个型号。
你能仔细检查一下吗?
对于N5700耗材,它是标准的SCPI查询:VOLT?
MAX CURR?
MAX这些应返回最大可编程值。
662xA是SCPI之前的,它有一个非常简单的编程接口。
唯一可以通过根据型号制作查找表来了解最大值的方法。
谢谢。
马特
以上来自于谷歌翻译
     以下为原文
  Hi Ajay,
I am not familiar with the first model numbers that you mention.  Can you double check them?
For the N5700 supplies, it is a standard SCPI query:
VOLT? MAX
CURR? MAX
These should return the maximum programmable values.
662xA was pre SCPI and it has a very simple programming interface.  The only way you would know what the maximums are is by making a lookup table based on the model number.
Thanks.
Matt
举报
高文军
2019-9-29 09:30:13
你能仔细检查一下吗?
嗨马特,谢谢你的回复。
我不知道这些标准查询。
我在N5700系列用户指南中找不到它。(http://cp.literature.agilent.com/litweb/pdf/5969-2917.pdf)E5280B / E5281B是进入E5270B测量主机的HPSMU和MPSMU
(http://www.home.agilent.com/sec/product.jspx?nid=-33786.536895055.00&lc=eng&cc=US)。
此致,Ajay
以上来自于谷歌翻译
     以下为原文
  Hi Matt,
Thanks for the reply.
I was not aware of these standard queries. I couldn't find it in the N5700 series user guide.(http://cp.literature.agilent.com/litweb/pdf/5969-2917.pdf)
E5280B/E5281B are the HPSMU and MPSMU that go into E5270B measurement mainframe (http://www.home.agilent.com/sec/product.jspx?nid=-33786.536895055.00&lc=eng&cc=US).
Regards,
Ajay
举报
罗敏
2019-9-29 09:47:22
我工作的安捷伦部分不拥有E5280 / E5281,但我确实得到了他们的答复:“E5270B是E5280B HPSMU或E5281B MPSMU的主机没有获取最大电压或电流的查询命令。
以上来自于谷歌翻译
     以下为原文
  The part of Agilent that I work for does not own the E5280/E5281 but I do have a response from them:
"E5270B which is the mainframe of E5280B HPSMU or E5281B MPSMU doesn't have a query command for getting maximum voltage or current."
举报
更多回帖
