是德科技
直播中
王莉淳
8年用户 260经验值
私信 关注
[问答]
4端口ENA系列分析仪校准出错
我在4端口ENA系列分析仪上遇到了部分校准问题。
如果我完成以下场景:场景1 ---------------- - 执行4端口校准,但在校准的反射部分出错,虽然Thru正确连接
- 执行部分校准,正确地重新进行反射(打开/短路/加载)场景2 --------------- - 执行4端口校准,但在通过时出错
虽然反射是正确连接的一部分。
- 执行部分校准,正确地重新执行直通电话在方案1中,最终校准总是不好,但在方案2中,这很好,为什么会这样?
在正确校准之前,似乎总是必须执行好反射校准。
以上来自于谷歌翻译
     以下为原文
  I've been having an issue with the Partial Calibration on the 4-port ENA series analyzer.
If I complete the following scenarios:
Scenario 1
- Perform a 4-port cal but make a mistake on the reflection part of the cal, the Thru is connected correctly though.
- Perform a partial cal, re-doing the reflection (Open/Short/Load) correctly
Scenario 2
- Perform a 4-port cal but make a mistake on the thru part of the cal, the Reflection is connected correctly though.
- Perform a partial cal, re-doing the Thru cals correctly
In scenario 1, the final calibration is always bad, but in scenario 2 it is good Why is this?
It seems like a good Reflection calibration always has to have been performed, before a Thru cal can be correct.
回帖(1)
孔德羲
2019-9-19 16:46:40
我不太熟悉ENA的内部细节,但这让我感到惊讶。
使用PNA,可以获取并存储所有原始数据,以便校准可以按任何顺序进行,最终结果根据最后取得的值计算得出。
也许ENA首先计算1端口错误条款并且不保存原始测量值,这可以解释为什么单端口测量中的错误传播到最终校准。编辑:Dr_joel于2013年1月21日下午9:28
以上来自于谷歌翻译
     以下为原文
  I'm not so familiar with the ENA internal details, but this surprises me.  With the PNA, all the raw data is taken and stored, so that the calibration can proceed in any order and the final result computed from the last values taken.  Perhaps the ENA first computes the 1 port error terms and doesn't save the raw measurements, this would explain why errors in one-port measurements propogate to the final cal.
Edited by: Dr_joel on Jan 21, 2013 9:28 PM
举报
更多回帖
