是德科技
直播中
吴民峰
8年用户 179经验值
私信 关注
[问答]
Hp6030A超范围错误
你好,我有一个电源HP6030与GPIB板的问题。设备上电,没有任何错误代码。我可以设置它应该给出的想要的输出电流,但当我开始立即移动慢跑时
我检查了所有电源部分,看起来没问题。我已经检查了A2控制板上连接器A2J7的所有信号,一切似乎都没问题。如果我已经很好理解了
仪器的功能,超范围(自动量程)限制是由uProcessor使用Vmon和Imon信号计算的。我认为2个信号相乘,结果用参考值验证,这意味着最大输出功率可能。所以如果我测量
电源后部或A2板上的Imon和Vmon完全是零。所以我认为上位处理器可能接收到数字化Imon和Vmon的错误值。这些信号通过多路复用器然后进入A /
D转换器。我怎么能检查t
他的部分电路?或者有人有同样的问题并解决了吗?先谢谢你的帮助
以上来自于谷歌翻译
     以下为原文
  Hello,
i've a problem with a power supply HP6030 with GPIB board.
The device power up and there isn't any error code.I can setup the wanted amount
output current that it should give,but when i start to move the jog immediatly
the led overrange ligth up and the voltage remian @ 0 volt.
I checked all the power section and seem to be ok.I've checked all the signal in
the connector A2J7 on A2 control board and all seem to be ok.
If i have well understood the functioning of the instrument, the
overrange(autorange) limit is calculated by the uProcessor using the Vmon and
Imon signals.
I think that the 2 signals are multiplied and the result is verified with a
value of reference that means max output power possible.
So if i mesure the Imon and Vmon in the rear of the supply or in the A2 board
they are perfecly @ zero.
So my opinion is that probably the uprocessor receive the digitalized Imon and
Vmon with a wrong value.
These signal pass trought a multiplexer and then into a A/D converter.
How could i check this part of circuit?
Or somebody had same problem and resolved it?
Thanks in advance for any help
回帖(2)
罗敏
2019-8-14 12:37:12
嗨,我会让我的同事知道这些用品在你的两篇文章中非常好用。坚持调整
以上来自于谷歌翻译
     以下为原文
  Hi,
I will have my colleague that knows these supplies very well pop in on your two posts.
Stay tuned
举报
吴民峰
2019-8-14 12:56:55
我会等!感谢PS电流变压器似乎不是霍尔效应,而是被动
以上来自于谷歌翻译
     以下为原文
  I'll wait!
Thanks
PS the Current transformer doesn't seem to be Hall effect,but passive
举报
更多回帖
