现在这个旁路声音已经没有了,
我对比了一下之前的配置和现在的配置,DACL和DACR都是使用默认值,我主要是对时钟部分做了调整,把MADC和MADC,DOSR和AOSR调为不一样,
void aic3204_init_different_mono(void)
SYS_EXBUSSEL = 0x6100; // Enable I2C bus
USBSTK5515_I2C_init( ); // Initialize I2C
/* Configure AIC3204 */
AIC3204_rset( 0, 0x00 ); // Select page 0
AIC3204_rset( 1, 0x01 ); // Reset codec
AIC3204_rset( 0, 0x01 ); // Select page 1
AIC3204_rset( 1, 0x08 ); // Disable crude AVDD generation from DVDD
AIC3204_rset( 2, 0x01 ); // Enable Analog Blocks, use LDO power
AIC3204_rset( 10, 0x00 ); //#Set the input common mode to 0.9V
AIC3204_rset( 61, 0x00 ); //#Set ADC PTM_R4
AIC3204_rset( 71, 0x00 ); //#Set MicPGA startup delay to 3.1ms
AIC3204_rset( 123, 0x01 ); //#Set the REF charging time to 40ms
/* PLL and Clocks config and Power Up */
AIC3204_rset( 0, 0 ); // Select page 0
AIC3204_rset( 27, 0x4d ); // BCLK and WCLK is set as o/p to AIC3204(Master) interface DSP
AIC3204_rset( 28, 0x02 ); //#Data offset value ( ajout de 1 BCLK's)
AIC3204_rset( 29, 0x08 ); //# Audio interface set
AIC3204_rset( 61, 0x01 ); //ADC Signal Processing Block Control Register
AIC3204_rset( 60, 0x8 ); //DAC Signal Processing Block Control Register
AIC3204_rset( 4, 3 ); // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK
AIC3204_rset( 6, 8 ); // PLL setting: J=8
AIC3204_rset( 7, 0x07 ); // PLL setting: HI_BYTE(D=1680)
AIC3204_rset( 8, 0x80 ); // PLL setting: LO_BYTE(D=1680)
AIC3204_rset( 30, 0xc0 ); // For 32 bit clocks per frame in Master mode ONLY
// BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs
AIC3204_rset( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1
AIC3204_rset( 13, 03 ); // Hi_Byte(DOSR) for DOSR = 768 decimal or 0x0300 DAC oversamppling
AIC3204_rset( 14, 0x00 ); // Lo_Byte(DOSR) for DOSR = 768 decimal or 0x0300
AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x80 for decimation filters 1 to 6
AIC3204_rset( 11, 0x88 ); // Power up NDAC and set NDAC value to 2
AIC3204_rset( 12, 0x82 ); // Power up MDAC and set MDAC value to 8
AIC3204_rset( 18, 0x88 ); // Power up NADC and set NADC value to 8
AIC3204_rset( 19, 0x8c ); // Power up MADC and set MADC value to 12
AIC3204_rset( 81, 0x00 ); // Power down Left and Right ADC
AIC3204_rset( 63, 0x14 ); // Power down left,right data paths and set channel
AIC3204_rset( 61, 2 ); // PRB_R2
// set biquad A to low pass fc = 3628
AIC3204_rset( 0, 8 ); // Select page 8
AIC3204_rset( 36, 0x6A ); // Left N0 H
AIC3204_rset( 37, 0xC3 ); // Left N0 M
AIC3204_rset( 38, 0x6F ); // Left N0 L
AIC3204_rset( 40, 0x35 ); // Left N1 H
AIC3204_rset( 41, 0x61 ); // Left N1 M
AIC3204_rset( 42, 0xB7 ); // Left N1 L
AIC3204_rset( 44, 0x00 ); // Left N2 H
AIC3204_rset( 45, 0x00 ); // Left N2 M
AIC3204_rset( 46, 0x00 ); // Left N2 L
AIC3204_rset( 48, 0xD5 ); // Left D1 H
AIC3204_rset( 49, 0x3C ); // Left D1 M
AIC3204_rset( 50, 0x91 ); // Left D1 L
AIC3204_rset( 52, 0x00 ); // Left D2 H
AIC3204_rset( 53, 0x00 ); // Left D2 M
AIC3204_rset( 54, 0x00 ); // Left D2 L
AIC3204_rset( 0, 9 ); // Select page 9
AIC3204_rset( 44, 0x6F ); // Right N0 H
AIC3204_rset( 45, 0x96 ); // Right N0 M
AIC3204_rset( 46, 0x52 ); // Right N0 L
AIC3204_rset( 48, 0x37 ); // Right N1 H
AIC3204_rset( 49, 0xCB ); // Right N1 M
AIC3204_rset( 50, 0x29 ); // Right N1 L
AIC3204_rset( 52, 0x00 ); // Right N2 H
AIC3204_rset( 53, 0x00 ); // Right N2 M
AIC3204_rset( 54, 0x00 ); // Right N2 L
AIC3204_rset( 56, 0xD0 ); // Right D1 H
AIC3204_rset( 57, 0x69 ); // Right D1 M
AIC3204_rset( 58, 0xAD ); // Right D1 L
AIC3204_rset( 60, 0x00 ); // Right D2 H
AIC3204_rset( 61, 0x00 ); // Right D2 M
AIC3204_rset( 62, 0x00 ); // Right D2 L
/* DAC ROUTING and Power Up */
AIC3204_rset( 9, 0x30 ); //# OUTPUT DRIVER POWER CONTROL hp->ON lineout->OFF mixer->OFF
AIC3204_rset( 10, 0x03 ); //#COMMON MODE CONTROL REGISTER Output of HP is powered by LDOIN
AIC3204_rset( 11, 0x10 ); //Over Current detection is enabled for HPL & HPR
AIC3204_rset( 12, 0x08 ); //# Left DAC (+) -> HPL
AIC3204_rset( 13, 0x00 ); //# Left DAC (-) -> HPR
AIC3204_rset( 14, 0x00 ); //# LOL is not routed
AIC3204_rset( 15, 0x00 ); //# LOR is not routed
AIC3204_rset( 16, 0x3c ); // HPL Driver gain setting register Unmute HPL , 0dB gain
AIC3204_rset( 17, 0x3c ); // volume de sortie headphone 0x00 -> 0dB 0x3A -> -6dB 0x1d -> +29dB
AIC3204_rset( 18, 0x40 ); //# LOL driver gain settings register
AIC3204_rset( 19, 0x40 ); //# LOL & LOR MUTED
AIC3204_rset( 20, 0x25 ); //#HEADPHONE DRIVER STARTUP Headphone amps power up slowly in 5.0 time constants / Headphone amps power up time is determined with 6K resistance
AIC3204_rset( 22, 0x00 ); //# IN1L to HPL volume control bypass 0dB
AIC3204_rset( 23, 0x00 ); //# IN1L to HPL volume control bypass 0dB
AIC3204_rset( 24, 0x00 ); //# MIXERAMP Left volume control
AIC3204_rset( 25, 0x00 );
AIC3204_rset( 51, 0x50 ); //# setting du micbias micbias = Vcc
AIC3204_rset( 64, 0x00 ); //#DAC L UNMUTED, R&L independant DAC R MUTED (mode differentiel)
//# 0x00 -> 0dB 0xFF -> -0.5dB 0x81 -> -63dB
AIC3204_rset( 65, 0x00 ); //# Left DAC channel digital volume control register
AIC3204_rset( 66, 0x00 ); //# Right DAC Channel Digital Volume Control Register
AIC3204_rset( 63, 0x90 ); //#DAC L switched ON, R OFF, soft-stepping enabled
/* ADC ROUTING and Power Up */
AIC3204_rset( 0, 1 ); // Select page 1
AIC3204_rset( 52, 0x30 ); //# IN2L -> Left MICPGA + 40K resistance
AIC3204_rset( 54, 0x30 ); //# IN2R -> Left MICPGA - 40K resistance
AIC3204_rset( 55, 0x00 ); //# Right MICPGA positive terminal input routing
AIC3204_rset( 57, 0x00 ); //# Right MICPGA negative terminal input routing
AIC3204_rset( 58, 0xbb ); //#Floating Input Configuration register
AIC3204_rset( 59, 0 ); // MIC_PGA_L unmute
AIC3204_rset( 60, 0 ); // MIC_PGA_R unmute
AIC3204_rset( 81, 0x80 ); //#ADC right OFF & left ON
AIC3204_rset( 82, 0x08 ); //#ADC left UNMUTED right MUTED
AIC3204_rset( 83, 0x67 ); //#ADC left & right channel volume control
AIC3204_rset( 84, 0x67 ); //#ADC volume 20dB -- 0x28 -12dB -- 0x67
AIC3204_rset( 85, 0x81 ); //#ADC phase adjust register
USBSTK5515_wait( 200 ); // Wait
// I2S settings
I2S0_SRGR = 0x0; //I2Sn Sample Rate Generator Register slave mode is invalide
//I2S0_CR = 0x9011; // 16-bit word, slave, enable I2C Mono mode
//I2S2_CR = 0x9e11;
I2S0_CR = 0x8010;
// I2S0_CR Address: 0x2800 ((I2S BUS) I2Sn Serializer Control Register (I2SSCTRL)
// |15:14:13:12|11:10: 9: 8| 7: 6: 5: 4| 3: 2: 1: 0| <<== Bit Position
// |rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw| <<== Read / Write Access
// | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| <<== Reset Values
// | 1 0: 0: 1| 0: 1: 1: 0| 0: 0: 0: 1| 0: 0: 0: 1| <<== current Values
// | | | | | | | | | | | | | | | +-- [0] FRMT (0:I2S/left-justified format, 1:DSP format)
// | | | | | | | | | | | | | | +----- [1] MODE (0:Serializer is configured as a slave, 1:master)
// | | | | | | | | | | | | | +-------- [2] WDLNGTH (0:clk active, 1:clk disabled)
// | | | | | | | | | | | | +----------- [3] WDLNGTH Choose serializer word length 8 10 .. 32
// | | | | | | | | | | | +-------------- [4] WDLNGTH
// | | | | | | | | | | +----------------- [5] WDLNGTH
// | | | | | | | | | +-------------------- [6] SIGN_EXT (0:No sign extension, 1:Received data is sign extended. Transmit data is expected to be sign extended.For more information about sign extension)
// | | | | | | | | +----------------------- [7] PACK (0:Data packing mode disabled, 1:Data packing mode enabled)
// | | | | | | | +-------------------------- [8] DATADLY (0:1-bit data delay, 1:2-bit data delay)
// | | | | | | +----------------------------- [9] CLKPOL (0:Controls I2S clock polarity, 1:.....XXX $$$ )
// | | | | | +-------------------------------- [10] FSPOL (0:Inverts I2S frame-synchronization polarity, 1:....XXX $$$)
// | | | | +----------------------------------- [11] LOOPBACK (0:Normal operation, no loopback, 1:Digital Loopback mode enabled)
// | | | +-------------------------------------- [12] MONO (0:Stereo mode, 1:Mono mode. Valid only when bit 0, FRMT=1 (DSP Format))
// | | +----------------------------------------- [13] Reserved
// | +-------------------------------------------- [14] Reserved
// +----------------------------------------------- [15] ENABLE (0:I2S disabled, 1:I2S enabled)
//I2S0_ICMR = 0x17; // Enable interrupts
I2S0_ICMR = 0x2b;
// I2SINTMASK Address: 0x2814 ((I2S BUS) I2Sn Interrupt Mask Register (I2SINTMASK)
// | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 1| 0: 1: 0: 0| <<== current Values
// | | | | | | | | | | | | | | | +-- [0] OUERR (0:Disable overrun/underrun error interrupt, 1:Enable overrun/underrun error interrupt.)
// | | | | | | | | | | | | | | +----- [1] FERR (0:Disable frame-synchronization error interrupt, 1:Enable frame-synchronization error interrupt.)
// | | | | | | | | | | | | | +-------- [2] RCVMON (0:Disable mono RX data interrupt, 1:Enable mono RX data interrupt.)
// | | | | | | | | | | | | +----------- [3] RCVST (0:Disable stereo RX data interrupt, 1:Enable stereo RX data interrupt)
// | | | | | | | | | | | +-------------- [4] XMITMON (0:Disable mono TX data interrupt, 1:Enable mono TX data interrupt)
// | | | | | | | | | | +----------------- [5] XMITST (0:Disable stereo TX data interrupt, 1:Enable stereo TX data interrupt)
// | | | | | | | | | +-------------------- [6] Reserved
// | | | | | | | | +----------------------- [7] Reserved
// | | | | | | | +-------------------------- [8] Reserved
// | | | | | | +----------------------------- [9] Reserved
// | | | | | +-------------------------------- [10] Reserved
// | | | | +----------------------------------- [11] Reserved
// | | | +-------------------------------------- [12] Reserved
// +----------------------------------------------- [15] Reserved
现在这个旁路声音已经没有了,
// I2S settings
//I2S2_CR = 0x9e11;
I2S0_CR = 0x8010;
I2S0_ICMR = 0x2b;
举报
