代码的顺序分别为head.S, led.c, Makefile
其中,除了led.c是借鉴韦老师的点灯程序,其他都是自己写的,我把0x56000000映射到0xb0000000,把sdram的地址映射到0xa0000000,这里的做法也和韦老师的相反,主要内容是head.S
以下是head.S代码:
.text
- .global _start
- _start:
- bl Disable_Watch_Dog
- bl MemSetup
- bl MMUSetup
- bl Copy_SteppingStone_to_Sdram
- ldr pc,=On_Sdram
- Disable_Watch_Dog: ;关看门狗
- mov r1,#0x53000000
- mov r2,#0
- str r2,[r1]
- mov pc,lr
- MemSetup: ;初始化SDRAM
- mov r1,#0x48000000
- adrl r2,SetMem_avl
- ldr r3,=0x48000034
- Loop1:
- ldr r4,[r2],#4
- str r4,[r1],#4
- cmp r1,r3
- bne Loop1
- mov pc,lr
- Copy_SteppingStone_to_Sdram: ;将程序复制到虚拟地址0xa0004000处运行
- mov r1,#0
- ldr r2,=0xa0004000
- mov r3,#4096
- Loop2:
- ldr r4,[r1],#4
- str r4,[r2],#4
- cmp r3,r1
- bne Loop2
- mov pc,lr
MMUSetup: ;初始化MMU
- ;建立4G内存空间页表
- mov r4,#0x30000000 ;页表基址
- ldr r3,=0x00000c12 ;domain 0,uncached,unbuffered
- mcr p15, 0, r4, c2, c0, 0 ;将页表基址存入C2中
- ldr r5,=0x1000 ;循环4K次(4K*1MB=4GB)
- l1:
- str r3,[r4],#4 ;建立页表
- add r3,r3,#(1<<20) ;更新描述符
- subs r5,r5,#1
- bne l1
- ;映射0x56000000到0xb0000000
- ldr r1,=0xfff00000
- mov r2,#0xb0000000 ;VA
- mov r0,#0x56000000 ;PA
- and r2,r2,r1
- orr r3,r3,r0 ;段描述符 4Byte
- add r4,r4,r2,lsr #(18) ;描述符地址=基址+虚拟段地址>>(20-2)位 ([1:0]位为00,4字节对齐)
- str r3,[r4]
;映射0x30000000到0xa0000000
- ldr r3,=0x00000c1e ;domain 0,cached,buffered
- mov r2,#0xa0000000 ;VA
- mov r0,#0x30000000 ;PA
- and r2,r2,r1
- mov r5,#64 ;SDRAM总共有64MB 循环64次
- l2:
- str r3,[r4],#4
- subs r5,r5,#1
- bne l2
- mov r0,#0
- mcr p15,0,r0,c7,c7,0 ;使无效ICache和DCache
- mcr p15,0,r0,c7,c10,4 ;清空缓冲区
- mcr p15,0,r0,c7,c5,4 ;清空预取缓冲区
- mcr p15,0,r0,c7,c5,6 ;清空整个跳转目标cache
- mcr p15,0,r0,c8,c7,0 ;使无效TLB
- mvn r0,#0
- mcr p15,0,r0,c3,c0,0 ;域访问控制寄存器设为0xFFFFFFFF,不进行权限检查
mrc p15,0,r0,c1,c0,0 ;读取C1内容到R0
- bic r0,r0,#0x3000
- bic r0,r0,#0x380
- bic r0,r0,#0x7
- orr r0,r0,#0x1000
- orr r0,r0,#0x7 ;开启对齐检查,使能ICache,使能DCache,打开MMU
- mcr p15,0,r0,c1,c0,0 ;将R0中内容写回C1中
- mov pc,lr
On_Sdram:
- mov sp,#0xa4000000 ;设置栈顶在SDRAM最上方
- bl main
- Halt_loop:
- b Halt_loop
- .align 4
- SetMem_avl:
- @ 存储控制器13个寄存器的设置值
- .long 0x02011110 @ BWSCON
- .long 0x00000700 @ BANKCON0
- .long 0x00000700 @ BANKCON1
- .long 0x00000700 @ BANKCON2
- .long 0x00000700 @ BANKCON3
- .long 0x00000700 @ BANKCON4
- .long 0x00000700 @ BANKCON5
- .long 0x00018009 @ BANKCON6
- .long 0x00018009 @ BANKCON7
- .long 0x00aC07A3 @ REFRESH
- .long 0x000000B1 @ BANKSIZE
- .long 0x00000030 @ MRSRB6
- .long 0x00000030 @ MRSRB7
复制代码
更多回帖
