SIO是一种特殊的输入引脚。它允许启用一些特殊特性(例如更高的输出驱动器,能够处理高于电源电压的输入电压)。正常和SIO引脚都可以设置为打开漏极。
也许我建议您阅读PSoC5LP数据表和PoS5LP的体系结构参考手册(TRM),解释了不同PIN类型的所有细节。
以上来自于百度翻译
以下为原文
SIO is a special kind of input pin. It allows for some special features to be enabled (e.g. higher output drive, ability to handle input voltages higher than supply voltage). Both normal and SIO pins can be set to open drain.
Maybe I suggest you read the PSOC5LP data sheet, and the architecture reference manual (TRM) for the PSoC5LP, there all the details about the different pin types is explained.
以上来自于百度翻译
以下为原文
举报
