嗨Peter,用于ESG-B和ESG-APDP的OLD ESG-B服务软件(版本A.07.01)可以从Agilent.com网站下载:http://www.home.agilent.com/agilent/facet。
jspx?k = esg-b + service + software& neighborhood = ETM& kt = 1& cc = US& lc = eng& homesearch = SearchThis软件自2004年以来未更新,不再受支持。
安捷伦测试管理环境(TME)软件目前支持ESG-B(包括APDP)。该软件具有ESG-B的所有性能验证测试和功率级准确度(PLA)调整。
如果需要,旧软件可用于所有其他调整.TME可从以下网址下载:http://calsw.tm.agilent.com/使用TME软件执行测试需要许可证。
许可证可从当地的安捷伦代表处购买。
有关更多信息,请访问:http://www.home.agilent.com/agilent/product.jspx?cc = US& cs = eng& ckey = 653989& nid = -34008.536907582.00& id = 653989Regards,John
以上来自于谷歌翻译
以下为原文
Hi Peter,
The OLD ESG-B service software (version A.07.01) for ESG-B and ESG-APDP can be downloaded from the Agilent.com website:
http://www.home.agilent.com/agilent/facet.jspx?k=esg-b+service+software&neighborhood=ETM&kt=1&cc=US&lc=eng&homesearch=Search
This software has not been updated since 2004 and is no longer supported. The ESG-B (including APDP) is currently supported with the Agilent Test Management Environment (TME) software.
This software has all Performance Verification tests and Power Level Accuracy (PLA) adjustment for the ESG-B. The old software can be used for all other adjustments if needed.
TME can be downloaded from:
A license is required to perform tests using the TME software. A license can be purchased from a local Agilent Representative. More information can be found at:
http://www.home.agilent.com/agilent/product.jspx?cc=US&lc=eng&ckey=653989&nid=-34008.536907582.00&id=653989
Regards,
John
许可证可从当地的安捷伦代表处购买。
以上来自于谷歌翻译
以下为原文
Hi Peter,
Regards,
John
举报
