嗨@ fmousse,你的意思是“模拟工作但不是实施”?
你是说你没有在电路板上获得相同的输出?
因为实现成功通过。谢谢,Nupur
谢谢,Nupur -----------------------------------------------
--------------------------------------------- Google在发布之前提问
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。
以上来自于谷歌翻译
以下为原文
Hi @fmousse,
What do you mean by "The simulation is working but not the implementation"? Do you mean you are not obtaining the same output on the board? Because the implementation is passing successfully.
Thanks,
NupurThanks,
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).
你是说你没有在电路板上获得相同的输出?
因为实现成功通过。谢谢,Nupur
以上来自于谷歌翻译
以下为原文
Hi @fmousse,
Thanks,
NupurThanks,
Nupur
举报
