你好@坎特纳
这些是使用FPGA测试的PROM。
如果使用除列出的舞会以外的其他舞会将从支持的角度考虑为不支持的Flash。
-Pratham ------------------------------------------------
----------------------------------------------请注意 - 请
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-
以上来自于谷歌翻译
以下为原文
Hi @kantner
These are the PROM which are tested with the FPGA. If using other than listed prom will be considered as non supported flash from support point of view.
-Pratham
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
你好@坎特纳
这些是使用FPGA测试的PROM。
以上来自于谷歌翻译
以下为原文
Hi @kantner
-Pratham
举报
