是德科技
直播中
王雪
7年用户 986经验值
私信 关注
[问答]
MXG矢量信号Generqtor N5182A对RF电平的影响
来自日本的致辞。
MXG矢量信号Generqtor N5182A具有高功率选项1EA,我收到了客户对RF电平的投诉。
详细说明:设置电源开启/最后仍然设置RF开启,在+23 dBm,其中连接和销毁的客户的电源开启,电气损坏样品(被测设备)。
当然,我必须在上电后立即向安捷伦日本报告任何设置,我希望您关闭RF。
在响应之后,没有看到任何动作并反馈到工厂开发。
客户这样麻烦你,但我不知道市场是否已经发生过?
以上来自于谷歌翻译
     以下为原文
  Hello Message from Japan.
MXG Vector Signal Generqtor N5182A with High power option 1EA, I have received a complaint about the RF level from my customers.
Details Description: Set Power on / last is still set RF on, at +23 dBm, where the power on, electrical damage  sample(Device Under Test) of customers who are connected and destroyed.
Of course, I have to report to the Agilent Japan in any setting, immediately after power-on, and I want you to OFF to RF. After the response, the movement is not seen nothing and feed back to the plant development.
Customers such trouble you, but I wonder if the market has occurred?
回帖(1)
李欢
2019-7-16 10:16:52
嗨 - 我猜你想开机关闭RF。
如果将“开机”设置为“预设”,则设备将在关闭RF的情况下启动。
您也可以关闭电源,然后将电源设置为最后。
如果这些都不起作用,您可以通过将Power On设置为User来定义自己的Power On。
这些软键可在Utility,Power On / Preset,Power On下找到。
请查看MXG-A用户指南的第27页。
http://cp.literature.agilent.com/litweb/pdf/N5180-90003.pdf我希望这有帮助 -
以上来自于谷歌翻译
     以下为原文
  Hi -
I am guessing you want to power On with the RF off.
If you have the Power On set to Preset then the unit powers up with the RF off.
Also you can turn the power off and then set the Power on to Last.
If neither of these work, you can define your own Power On by setting the Power On to User. These softkeys can be found under Utility, Power On/Preset, Power On.
Please look at page 27 of the MXG-A Users Guide.
I hope this helped -
举报
更多回帖
