是德科技
直播中
刘平
8年用户 240经验值
私信 关注
[问答]
ESG-DP服务软件有明显错误
我正在尝试进行性能验证,并可能对E4436B(ESG-DP)信号发生器进行校准。
我在Windows XP笔记本电脑上使用Agilent服务支持软件(版本B.07.00,ESG_APDP版本B6.3),并在ESG上安装了82357A USB-GPIB接口。
根据服务软件随附的说明,这是一个有效的设置。
尽管Agilent IO Lib驱动程序可以看到ESG并与其进行通信,但服务软件的SICL库似乎存在问题。
当我调用任何测试并尝试运行它时,服务软件给我以下错误消息:#207 EQUIPMENT ERROR:型号:E4436B,序列号US3926xxxx,驱动程序:C: HP_SVC  DRIVERS  DRV4400B.dll。
无法初始化SICL库。
验证HPIB地址和连接,如果问题仍然存在,请重新启动系统。我选择运行Fractional N Board的性能测试,因为它不需要其他设备。
我已经验证了所有的连接和地址,并且我已经多次重启了笔记本电脑。
我已删除并重新安装了Agilent IO Libs,甚至将其从最新版本(16.1)降级到82357A接口(M01.01)附带的版本。
我重新安装了服务支持软件。
似乎没有任何帮助,我无法看到任何明显错误的硬件设置或我的软件安装。任何人都指出我正确的方向来解决这个问题吗?谢谢,斯坦
以上来自于谷歌翻译
     以下为原文
  I am trying to do a performance verification and possibly a calibration of an E4436B (ESG-DP) signal generator. I am using the Agilent Service Support Software (Version B.07.00, ESG_APDP Version B6.3) on a Windows XP laptop with an 82357A USB-GPIB interface to the ESG. According to the instructions supplied with the service software, this is a valid setup. Although the Agilent IO Lib drivers can see the ESG and communicate with it just fine, the service software seems to be having a problem with its SICL libraries. The service software gives me the following error message when I invoke any test and try to run it:
#207 EQUIPMENT ERROR: Model: E4436B, Serial Number US3926xxxx, Driver: C:HP_SVCDRIVERSDRV4400B.dll. SICL libraries could not be initialized. Verify HPIB addresses and connections, and if the problem persists, reboot your system.
I chose to run the performance test of the Fractional N Board since it required no other equipment. I have verified all of the connections and addresses, and I have rebooted the laptop several times. I have removed and reinstalled the Agilent IO Libs, even downgrading it from the latest version (16.1) to the version that came with the 82357A interface (M01.01). I have reinstalled the Service Support Software. Nothing seems to help, and I can't see anything obviously wrong with either my hardware setup or my software installation.
Can anyone point me in the right direction to get this sorted out?
Thanks,
Stan
回帖(4)
李欢
2019-7-15 11:26:19
嗨Stan - 请检查IO库上的设置。
我认为这是SICL设置问题。
请将其设置为HPIB7。
问候 -
以上来自于谷歌翻译
     以下为原文
  Hi Stan -
Please check the setting on the IO libraries.  I believe it is the SICL setting issue.  Please set it to HPIB7.
Regards -
举报
李欢
2019-7-15 11:40:57
Hi Stan - 锁定角度电位器调整是测试选择选项卡中KV VS FREQUENCY CAL之前的测试。
测试名称标记为“LOCK ANGLE POT ADJ”。如果您仍然无法找到它,请告诉我。
问候 -
以上来自于谷歌翻译
     以下为原文
  Hi Stan -
The Lock Angle Potentiometer Adjustment is the test just before the KV VS FREQUENCY CAL in the Test Selection tab.  The test name is labeled as “LOCK ANGLE POT ADJ”.
Do let me know if you still unable to find it.
Regards -
举报
刘平
2019-7-15 11:49:28
这变得更加有趣!
锁定角度电位器调整肯定存在于软件的ESG-B端(例如,如果我告诉它我有E4432B),但ESG-AP / DP端不存在(当我告诉它时)
我实际拥有的内容:E4436B)。在我的服务支持软件(版本B.07.00,ESG_B版本B7.0,ESG_APDP版本B6.3)中选择了“调整”单选按钮,并选择了E4436B仪器,顺序为
测试是:ANALOG BUS ADCPRETUNE CAL.VCO BIAS POT ADJ.INTERNAL SOURCE CAL.KV VS FREQUENCY CAL.TIME BASE DAC CAL.FM SCALE DAC OFFSET CAL ....等这是软件的问题,或者是
ESG-AP / DP仪器中不需要锁定角度调整?
我仔细查看了校准指南,找不到任何表明不应该或不能在ESG-AP / DP仪器上进行此调整的内容。
有解决方法吗?
有没有办法告诉软件在我的E4436B上运行这个调整?
(例如,通过告诉软件该仪器是E4432B,或以某种方式将Lock Angle Pot测试安装到软件的AP / DP“侧”来说谎软件。)问候,Stan
以上来自于谷歌翻译
     以下为原文
  This is becoming even more intriguing! The Lock Angle Potentiometer adjustment is definitely present in the ESG-B side of the software (if, for example, I tell it I have an E4432B), but it is not present in the ESG-AP/DP side (when I tell it what I actually have: an E4436B).
In my Service Support Software (Version B.07.00, ESG_B Version B7.0, ESG_APDP Version B6.3) with the "Adjustments" radio button selected, and an E4436B instrument selected, the order of the tests is:
ANALOG BUS ADC
PRETUNE CAL.
VCO BIAS POT ADJ.
TIME BASE DAC CAL.
FM SCALE DAC OFFSET CAL.
etc.
Is this a problem with the software, or is the lock angle adjustment not necessary in the ESG-AP/DP instruments? I looked very carefully at the Calibration Guide and couldn't find anything that would indicate that this adjustment shouldn't or couldn't be done on the ESG-AP/DP instruments.
Is there a workaround? Is there a way to tell the software to run this adjustment on my E4436B? (For example, lying to the software by telling it that the instrument is an E4432B, or somehow installing the Lock Angle Pot test into the AP/DP "side" of the software.)
Regards,
Stan
举报
刘平
2019-7-15 11:56:34
我想我可能有答案。
锁定角度电位器调节显然是一个物理电位器,位于ESG-B发生器的A12合成器板上。
ES12-DP仪器中没有A12板,因此不需要调整,甚至不可能.Regards,Stan
以上来自于谷歌翻译
     以下为原文
  I think I may have the answer. The Lock Angle Potentiometer adjustment apparently is a physical potentiometer that is on the A12 synthesizer board in the ESG-B generators. The A12 board is not present in the ESG-DP instruments, therefore, no adjustment is necessary, or even possible.
Regards,
Stan
举报
更多回帖
