ST意法半导体
直播中
冯超
7年用户 229经验值
私信 关注
[问答]
无法理解eDesign Studio Viper26的原理图
大家好,
我花了几个星期的时间试图找到一种AC / DC转换器小型化的解决方案。
今天我以为我已经找到了使用Viper26和精湛的eDesignSuite工具的解决方案,但是当我分析附加的结果电路时,我只是不明白两个不同接地的含义,用三角形表示(电路接地,我猜)和其他由三条水平条纹代表(也许是地球插头?)。
在丰富的文档ST中,我没有找到任何描述,也没有找到这两种类型的理由的例子,此外,我发现令人震惊的是GND / Source输出直接连接到电路接地并通过D连接到另一个接地(地球插头?)。
我感谢您的帮助。感谢您的时间和关注。
以上来自于谷歌翻译
以下为原文
Hi to all,
I take weeks trying to find a solution for miniaturization of an AC / DC Converter.
Today I thought I had found the solution with the Viper26 and superb eDesignSuite tool but when I analyzed the attached resulting circuit, I just do not understand the meaning of the two different grounds, represented by a triangle (circuit ground, I guess) and the other represented by three horizontal stripes (earth plug, perhaps?).
In the abundant documentation ST, I haven't found anything nor description, nor examples with these two types of grounds, besides, I find it shocking that the GND/Source output is connected directly to the circuit ground and through D to the another ground (earth plug?).
I appreciate your help. Thank you for your time and attention.
回帖(2)
冯超
2019-7-8 17:38:42
谢谢Marcello。
我真的不明白这个“设备看到的GND电平”,但实际上,重要的是要有一个正常工作的电路。
我不是说英语的人,所以,我感谢您确认我所说的附加电路是否正确。
新的,谢谢和最好的问候,
以上来自于谷歌翻译
以下为原文
Thank you, Marcello.
I really don't understand this ''the GND level seen by the device'', however, in fact, the important thing is to have a functioning circuit.
I am not English speaker so, please, I appreciate that you confirm me that the attached circuit with the modifications indicated by you, is correct.
Newly, thanks and best regards,
举报
冯超
2019-7-8 17:46:15
拜托,马塞洛,你能回答我的上一篇文章吗?谢谢
以上来自于谷歌翻译
以下为原文
Please, Marcello, can you answer my last post?. Thanks
举报
更多回帖
