是。
如果启用了“共享”,则可以执行以下操作,例如: - 在作用域上,将C: Temp声明为共享,名称为ScopeTemp - 在主机上,将作为驱动器S的作用域共享目录“ScopeTemp”连接到作用域:
存储在作用域上的文件C: Temp abc.png将在主机上以S: abc.png的形式提供。这是标准的Windows内容,并且自Win '95之前就已成为Windows的一部分。
您可能不得不使用权限和用户名,具体取决于您的环境。
以另一种方式执行此操作可能更容易,在主机上选择您可共享的目录。
- 在主机上,将C: ScopeDrop声明为共享,名称为HostDrop - 在作用域上,连接到主机共享目录,如驱动器H:作为H: abc.png存储在作用域上的文件将在
主持人为C: ScopeDrop abc.png Al
以上来自于谷歌翻译
以下为原文
Yes.
If Sharing is turned on, you can do the following, as an example:
- On the scope, declare C:Temp as shared, with name ScopeTemp
- On the host, connect to the scope shared directory 'ScopeTemp' as drive S:
A file stored on the scope as C:Tempabc.png will be available on the host as S:abc.png
This is standard Windows stuff, and has been part of Windows since before Win '95. You may have to mess around with permissions and user names, depending on your environment.
It might be easier to do it the other way, picking a directory on the host that you make shareable.
- On the host, declare C:ScopeDrop as shared, with name HostDrop
- On the scope, connect to the host shared directory, as Drive H:
A file stored on the scope as H:abc.png will be available on the host as C:ScopeDropabc.png
Al
是。
以上来自于谷歌翻译
以下为原文
Yes.
Al
举报
