Cypress技术论坛
直播中
张杰
8年用户 255经验值
私信 关注
[问答]
PSoC Creator 2.2无法加载项目工作区
所以我试着用PSoC Creator 2.2打开我的项目。PSoC Creator从不上我的电脑。iCek的过程,它表明有一个过程的PSoC Creator,但它从来没有打开启动菜单的PSoC创建者2.2或我的工作区。
以上来自于百度翻译
     以下为原文
  So I am trying to open my project with PSoC Creator 2.2. PSoC Creator never loads up on my computer. Icheck the processes and it shows that there is a process for PSoC Creator, but it never opened the starting menu of PSoC Creator 2.2 or my workspace.
回帖(5)
王琳
2019-7-4 11:44:59
如果您没有尝试用创建者3打开项目,我建议重新安装创建者2.2。鲍勃
以上来自于百度翻译
     以下为原文
          If you did not try to open the project with Creator 3.0 before I would suggest to re-install creator 2.2.
Bob
举报
姜钰
2019-7-4 11:54:45
在这种情况下,我通常看到的是,Creator要求更新项目或其组件。此对话框阻止创建者完全加载,并且它从不出现在任务栏中。我通常只在最小化所有其他程序窗口(BoT不使用“显示桌面”函数/快捷方式,因为这也隐藏了对话框……”之后发现违规对话框。
以上来自于百度翻译
     以下为原文
  What I see in such situations normally is that Creator asks about updating the project or its components. This dialog prevents Creator from loading fully, and it never shows up in the task bar. I usually find the offending dialog only after minimizing all other program windows (bot not with the 'show desktop' function / shortcut, as this hides the dialog too...)
举报
张杰
2019-7-4 12:10:26
所以我重新安装了PSoC Creator 2.2。我打开了工作空间,它工作了。
现在我关闭了创作者,关掉了电脑。刚才打开了我的电脑,我也遇到了和以前一样的问题。显然,在我遇到这个问题之前,我只能使用PSoC Cureor 2.2一次。有什么办法来解决这个问题吗?
以上来自于百度翻译
     以下为原文
  So I reinstalled PSoC Creator 2.2 again. I opened my workspace and it worked.
    Now I closed the Creator and turned off the computer. Turned on my computer just now, and I am experiencing the same problem as before. Apparently I can only use PSoC Craetor 2.2 once before I run into the problem. Is there any way to fix this problem?
举报
杨军
2019-7-4 12:26:40
多年来,我在Win注册中心遇到了反复出现的问题。
被破坏,不会打开程序。我用过各种扫描仪。
修复,诺顿赢得博士,系统机械师,先进的系统护理
我总是把钥匙固定好。我做这个每月或当我突然
不能再打开一些程序。
问候,Dana。
以上来自于百度翻译
     以下为原文
  I have had recurring problems over the years where Win registry
    gets trashed and will not open programs. I have used various scanners
    to fix, Norton win doctor, system mechanic, advanced systemcare
    and I always get reg keys fixed. I do this monthly or when I suddenly
    can no longer open some programs.
    Regards, Dana.
举报
更多回帖
