Cypress技术论坛
直播中
陈茗卓
7年用户 153经验值
私信 关注
[问答]
如何通过改变VCO频率来获得正确的时钟频率?
我使用时钟向导生成时钟配置文件,并将文件下载到CY3679工具包,但是我希望的时钟频率与实际频率不一致,为什么?我很困惑,我可以通过改变VCO频率来获得正确的时钟频率。那么,我应该怎么做才能产生我想要的频率呢?时钟配置文件在附件中,谢谢!
15 K
以上来自于百度翻译
     以下为原文
  I use Clock Wizard to generate Clock configuration file,and download the file to CY3679 kit.But the clock frequency I desired is not consistent with the actual  frequency,Why ?I am so puzzled ,I can get the correct clock frequency by changing VCO  frequency.So,what should I do to generate any frequency I desired? The  Clock configuration file is in the attachment.Thank you!
回帖(1)
郝思雨
2019-7-4 10:02:17
你好,
我们检查了从您所附的CalthWistar表,发现配置输出的PPM错误非常高。这可能是错误的输出频率的原因。你能提供你的要求(输入频率和要求的输出频率)还是附加时钟精灵项目?然后,我们可以为您的应用程序创建一个新项目。
谢谢和问候,
苏德什
以上来自于百度翻译
     以下为原文
  Hi,
    We checked the table from ClockWizard you attached and found that the PPM error for the configured outputs are very high. This can be the reason for wrong output frequencies. Can you provide your requirement (Input frequency and required output frequencies) or, attach your clock wizard project? Then we can create a new project for your application.
    Thanks and Regards,
    Sudheesh
举报
更多回帖
