Cypress技术论坛
直播中
刘彦妤
8年用户 255经验值
私信 关注
[问答]
为何CY8CCIT001和CY8C58LP系列在我按下板上的重置按钮后工作正常?
嗨,我用PSOC5开发包CY8CKIT-1001与CY8C5LP家族和Psoc Creator 2,我用蓝牙发送数据到PC。以前,它工作没有问题,但现在它不能正常工作,断电后,与PC的通信没有正确地建立,直到我按下工具箱板上的重置按钮。原因何在?问候Salima
以上来自于百度翻译
     以下为原文
          Hi, I am using the PSoC5 development kit CY8CKIT-001 with CY8C5Lp Family and Psoc Creator 2.0, and i send data to the Pc with Bluetooth. previously it worked without problems, but now it doesn´t work correctly, after power off-on the communication with Pc is not correctly established until i press the reset button on the Kit Board. what could be the reason? regards Salima
回帖(6)
刘晓燕
2019-7-3 09:27:21
嗨,SZaari You说“关机”只是在BT设备上的意思,PSoC还活着吗?如果是这样,似乎BT设备需要重新初始化,简单地说。还是另一个问题?
以上来自于百度翻译
     以下为原文
          Hi SZaari
You said "power off-on"
It's mean off-on only BT device and PSoC is still alive?
If so, it seems BT device need to re-initializing, simply.
Or another issue?
举报
刘彦妤
2019-7-3 09:41:01
我的意思是完整的系统PSoC板和BT模块
以上来自于百度翻译
     以下为原文
          no I mean the complete system psoc board and BT module
举报
刘彦妤
2019-7-3 09:58:04
我写了一个错误,我有CY8C55家族而不是CY8C58LP家族
以上来自于百度翻译
     以下为原文
          I have written an error, I have CY8C55 Family and not CY8C58LP Family
举报
刘晓燕
2019-7-3 10:09:11
我看,这似乎是电子启动序列的问题。温启动:BT在接受启动命令时电子稳定。另一方面,冷启动:当BT接受启动命令时,BT不足以上升。因此,在将初始命令提交给BT模块进行测试之前,最好设置CyDelphi。好啊?
以上来自于百度翻译
     以下为原文
          I see,
It seems issue of start up sequence on electronically.
Warm start: the BT is stable in electronically when accept initiate command.
The other hand,
Cold start: when the BT accept initiate command, BT is not enough to rise up.
So, you would be better set CyDelay before submit the initial command to the BT module for a TEST.
OK?
举报
更多回帖
