ST意法半导体
直播中
林邵嫔
7年用户 186经验值
私信 关注
[问答]
如何解决Eclipse Marketplace错误问题?
大家好,
我已经安装了SPC5Studio,并且按照指示,我已经尝试从Eclipse Marketplace安装编译器,但是我收到了以下错误消息:
''MarketplaceDiscoveryStrategy因错误而失败
无法完成对http://vps182808.ovh.net:9090/marketplace/api/p?product=com.st.tools.spc5.studio.spc5Studio&platform.version=4.4.2.v20150204-1700&os=的请求的win32&安培; java.version = 1.8.0_45&安培;客户= org.eclipse.epp.mpc.core&安培; product.version = 3.0.0.201512011640&安培; runtime.version = 3.10.0.v20140318-2214&安培; WS = win32的&安培; NL = it_IT :无法在http://vps182808.ovh.net:9090/marketplace/api/p?product=com.st.tools.spc5.studio.spc5Studio&platform.version=4.4.2.v20150204-1700&阅读存储库。 OS =&的win32放大器; java.version = 1.8.0_45&安培;客户= org.eclipse.epp.mpc.core&安培; product.version = 3.0.0.201512011640&安培; runtime.version = 3.10.0.v20140318-2214&安培; WS = win32的&安培; NL = it_IT。
无法在http://vps182808.ovh.net:9090/marketplace/api/p?product=com.st.tools.spc5.studio.spc5Studio&platform.version=4.4.2.v20150204-1700&os上阅读存储库= win32的&安培; java.version = 1.8.0_45&安培;客户= org.eclipse.epp.mpc.core&安培; product.version = 3.0.0.201512011640&安培; runtime.version = 3.10.0.v20140318-2214&安培; WS = win32的&安培; NL = it_IT。
vps182808.ovh.net:9090没有回复''
你能帮助我吗?
谢谢!
以上来自于谷歌翻译
以下为原文
Hello everybody,
I've installed SPC5Studio and, following the indication, I've tried to install the compiler from Eclipse Marketplace, but I've received the following error message:
''MarketplaceDiscoveryStrategy failed with an error
Cannot complete request to http://vps182808.ovh.net:9090/marketplace/api/p?product=com.st.tools.spc5.studio.spc5Studio&platform.version=4.4.2.v20150204-1700&os=win32&java.version=1.8.0_45&client=org.eclipse.epp.mpc.core&product.version=3.0.0.201512011640&runtime.version=3.10.0.v20140318-2214&ws=win32&nl=it_IT: Unable to read repository at http://vps182808.ovh.net:9090/marketplace/api/p?product=com.st.tools.spc5.studio.spc5Studio&platform.version=4.4.2.v20150204-1700&os=win32&java.version=1.8.0_45&client=org.eclipse.epp.mpc.core&product.version=3.0.0.201512011640&runtime.version=3.10.0.v20140318-2214&ws=win32&nl=it_IT.
vps182808.ovh.net:9090 failed to respond''
Could you kindly help me?
Thanks!
回帖(2)
林邵嫔
2019-6-26 16:17:06
我能够下载编译器。我想现在我应该通过''外部工具配置'配置编译器。
我可能需要编译器的位置和参数以及其他设置。你能告诉我这些信息吗?
再次感谢,
切尔
以上来自于谷歌翻译
以下为原文
I was able to download the compiler. I guess that now I should configure the compiler through the ''external tool configuration''.
I probably need the location and the arguments of the compiler and maybe other settings. Could you provide me this information?
Thanks again,
Cel
举报
刘鑫
2019-6-26 16:24:19
你好Cel,
当你转换成ppc-freevle-eabi-
选项自动设置。
编译器更新基于具有VLE支持的标准gcc分发。
你可以在这里找到gcc 4.9.3文档:
 最好的祝福
 二万
以上来自于谷歌翻译
以下为原文
Hello Cel ,
When you are switching into ppc-freevle-eabi-
the options are automatically set.
The compiler update is based on a standard gcc distribution with VLE support.
You can find gcc 4.9.3 documentation here:
  Best regards
               Erwan
举报
更多回帖
