Microchip
直播中
李永清
7年用户 189经验值
私信 关注
[问答]
ICD3错误0040无法调试dsPIC33FJ64GS606
大家好,经过多年的微控制器,我第一次遇到这个错误,我花了半个下午试图摆脱它,但没有成功。我的情况如下:我在一个新的板上有AdSPIC3FJ64 GS606,它被ICD3正确识别,我使用PGC/PG。D3端口(正确设置在MPLAB 8.88 -是的,我仍然使用旧版本,我不理解任何在新的……)如果我使用ICD3作为程序员,一切工作良好的所有振荡器配置(内部,XT,有或没有PLL……)。当我使用它作为调试器时,程序被写入,验证,但是我得到0040错误。我已经检查了微控制器的安装,它看起来很好,程序员引脚似乎是正确的引脚上的连接器,复位只有一个100K上拉,它是直接连接到TH。电路板几乎完全无人居住(只有SPI总线上的ADC和M3322收发器,我不认为它们能在这一点上干扰),我已经尝试过任何可能的保险丝设置组合,但结果总是一样的。当编程和执行速度根据振荡器设置改变时,我倾向于排除振荡器或板本身的硬件问题。IC PIS与ICD连接器之间的电阻是0.4OHM,所以我也排除了焊接的一些问题,ICD电缆是标准的短路,作为USB电缆。连接器只放置在离微控制器几毫米的地方,所以轨道很短。程序还没有做任何事情,只是将一个端口设置为输出并闪亮LED,因为我把所有的东西都移除了,以确保那里没有干扰。我明天唯一能做的就是组装一个第二个PCB,测试一个只排除一个微控制器故障,所以任何建议都是非常欢迎的。谢谢!吉安保罗
以上来自于百度翻译
      以下为原文
    Hi all,
after many years of microcontrollers I have encountered for the first time this error and I have spent half afternoon trying to get rid of it, but without success.
My situation is as follows:
I have a dsPIC33FJ64GS606 on a new board, it is correctly identified by the ICD3, I am using the PGC/PGD3 port (correctly set in MPLAB 8.88 -yes, I am still using the old version, I do not understand anything in the new one...).
If I use the ICD3 as a programmer, everything works fine with all oscillator configuration (internal, XT, with or without PLL...). When I use it as a debugger, the program gets written, verified, but I get the 0040 error.
I have checked the mounting of the microcontroller and it seems fine, the programmer pins seems to be going to the correct pins on the connector, the reset has only a 100k pullup and it is wired directly to the ICD connector.
The PCB is almost completely unpopulated (only an ADC on the SPI bus and a MAX3232 transceiver, I don't think they can interfere at this point), I have tried any possible combination of fuse settings I could think of, but the result is always the same.
Since the microcontroller works when programmed and the execution speed changes according to the oscillator setup, I tend to exclude an hardware issue with the oscillator or with the board itself. The resistance between the IC pis and the ICD connector is 0.4Ohm, so I would also exclude some problem with soldering, the ICD cable is the standard short one, as the USB cable. The connector is placed only a few millimeters away from the microcontroller, so tracks are very short.
The program is not doing anything yet, just setting one port as output and flashing a led, since I removed everything to be sure that there were no interference from there.
I am quite out of ideas, the only thing I can try tomorrow is to assembly a second PCB and test that one just to exclude a microcontroller failure, so any suggestion is very welcome.
Thanks!
Gian Paolo
回帖(12)
李博
2019-6-21 09:12:37
我不这么认为……所有的代码保护都关闭了,我也试过完全擦除设备。从一开始我就不能在调试模式下连接,而且在设备配置窗口中也没有看到任何“可疑”……你知道我需要检查的具体设置吗?
以上来自于百度翻译
      以下为原文
    I don't think so...
All code protections were off, I have tried also the complete erase of the device.
I was not able to connect in debug mode since the beginning and I have not seen anything "suspicious" in the device configuration window...
Do you know any specific setting that I may have to check?
举报
李博
2019-6-21 09:24:59
该死的!mad:http://www1.micro..com/downloads/en/DeviceDoc/80000489L.pdfDevice调试在使用PGEC3/PGED3时钟/数据引脚时不起作用。我讨厌这些东西!现在将是一个混乱,修补PCB和交换连接的两个引脚!嗯…
以上来自于百度翻译
      以下为原文
    Damn it! mad:
http://ww1.microchip.com/downloads/en/DeviceDoc/80000489L.pdf
Device debugging is not functional when using the PGEC3/PGED3 clock/data pins.
I hate these things! Now it will be a mess to patch the PCB and swap the connections of two pins! ARGHHH....
举报
王璨
2019-6-21 09:49:50
真正的程序员使用调试器来评估外围设置,而不用编写一行代码:(我承认:只有在特殊情况下)。但这不会是第一次……
以上来自于百度翻译
      以下为原文
    real programmers USE debuggers - to evaluate the peripheral setup without writing a single line of code :)
(I admit: only in special cases. But it wouldn't be for the first time...)
举报
王璨
2019-6-21 10:07:51
真正的程序员不焊接——他们修补软件。最好是在HexFobe上完成。一个同事被称为Pt'''Huffisher。(他的姓听起来有点像那个。)他修改了8051机器代码的十六进制,把十六进制文件带回来了,并且有一个年轻的团队将补丁反向工程成源代码。虽然一些补丁只是const值的变化。很有趣,但不是“绿色”的同事…
以上来自于百度翻译
      以下为原文
    real programmers don't solder - they patch the software. Best to be done on the hexfile.
A colleague was called Patch'n'hacker. (His surname sounded a bit like that.)
He modified 8051 machine code in hex, brought the hexfile back and had a younger colleage to reverse engineer the patches into source code. Though some of the patches were just changes of const values. Quite funny, but not for the 'green' colleague...
举报
更多回帖
