Cypress技术论坛
直播中
李恩佳
7年用户 210经验值
私信 关注
[问答]
请问有可能连接几个巴士的碎片吗?
有可能连接几个巴士的碎片吗?
33.5 K
以上来自于百度翻译
     以下为原文
  Is it possible to connect the fragments of severalBUS
回帖(15)
姜钰
2019-6-12 06:19:12
至少不要让它看起来比你原来的解决方案好得多。你能做什么:
画出你的两辆公共汽车每辆公共汽车,创建7个突破线分配每个突破线与适当的位(0 - 6),然后你可以连接突破线彼此,我测试了这一点,巴士仍然保持原来的名字。
更正:我只是试图建立这个项目,并得到了错误:“CRL和SR连接,并有不一致的基名”。
所以这不起作用,似乎没有得到支持。但最终,这是有意义的,因为网络需要有一致的名称来确保正确的路由。
我建议你创建一个包含数据线和TH4时钟的总线。然后你可以只连接你真正需要的线,就像你在任何其他的图解编辑器中一样。
以上来自于百度翻译
     以下为原文
  At least not making it looking much better than your original solution. What you can do:
  • draw your two busses
  • for each bus, create 7 breakout wires
  • assign each breakout wire with the proper bit (0-6)
  • then you can connect the breakout wires with each other
    I tested this, and the busses still kept their original names.
    Correction: I just tried to build this project, and got the error: "CRL and SR are connected and have inconsistent base names".
    So this doesn't work, and seems not to be supported. But in the end this makes sense that way - nets need to have consistent names to ensure proper routing.
    I would propose you create a bus containing the data lines and th4 clock. Then you can connect only the lines you really need, like you would do in any other schematics editor.
举报
李恩佳
2019-6-12 06:31:17
谢谢。遗憾的是,我不能在不同的公共汽车上指定几个导体的通用名称。技术支持信息:当我编辑总线并有错误-即使在总线移除后仍然存在错误。我必须关闭这个项目,然后再下载它。下面附有这样一个错误的例子。
184 K
以上来自于百度翻译
     以下为原文
  thanks. It is a pity that I can not assign a common name of several conductors in different bus.
Information for Technical Support:
 When i edit bus and has error - error remains even after removal of the bus.
 I have to close the project and download it again.
 An example of such an error is attached below.
举报
王琳
2019-6-12 06:40:51
解决这个命名问题的一个非常不寻常的方法是编写自定义组件,并希望优化程序。
鲍勃
以上来自于百度翻译
     以下为原文
  A very unusual way to get out of this naming-problem could be to write a custom-component and hoping for the optimizer.
    Bob
举报
王琳
2019-6-12 06:59:22
是的,这种方法有效,见附件项目
鲍勃
设计01.BuffLe011Zip
1.3兆字节
以上来自于百度翻译
     以下为原文
  Yes, that approach works, see attached project
    Bob
举报
更多回帖
