ST意法半导体
直播中
张大妍
8年用户 192经验值
私信 关注
[问答]
LIS3DH 5kHz ODR线路数量不对
大家好,
我想使用LIS3DH加速度计和带有ST Unico GUI的Steval-MK1109v2主板来记录加速度数据。
LIS3DH的数据表显示了可以测量高达5000Hz的带宽,这是我的振动器测量所需要的。
我使用Unico GUI将传感器配置为+ -2g和5000Hz模式。
我在振动器上尝试了一个160Hz的正弦信号并在Unico GUI上进行了在线FFT,但是在大约600Hz处出现了一个峰值,所以我看了一下.txt文件中的记录数据。我想添加一个时间路径,但认识到线路的数量根本不对。
我在大约3秒内记录了数据,但只得到了大约4000行。 ODR为5000Hz,预计可达16000线。
我测试了400Hz和1250Hz的模式,并且在线-FFT记录的数据都是正确的。
如果我之前使用0.0008s时间步长(1 / 1250Hz)记录5000Hz模式,它看起来是正确的......
所以我的问题是:
Unico GUI是否仅以高达1250Hz的速率记录数据(即使在5000Hz模式下),还是Unico GUI软件中的错误?
如果我查看GUI的错误在线FFT,其中显示600Hz但肯定只给出160Hz信号,它看起来就像那样。
我有点困惑。
谢谢你的帮助!
问候,
马库斯舒尔茨
#lis3dh-ODR-带宽UNICO贵
以上来自于谷歌翻译
以下为原文
Hello all,
I want to use the LIS3DH accelerometer and a Steval-MK1109v2 Motherboard with the ST Unico GUI for logging Acceleration data.
The datasheet of the LIS3DH shows the possibility to meassure a bandwidth up to 5000Hz, which i need for my shaker meassurements.
I used the Unico GUI to configure the Sensor at +-2g and the 5000Hz mode.
I tried a 160Hz sine signal at the shaker and made an online FFT at the Unico GUI, but there was shown a peak at about ~600Hz, so i took a look at the logged data in the .txt-file. I wanted to add a timepath but recognised that the number of the lines weren�t right at all.
I logged data at about 3 seconds but got only roundabout 4000 lines. With a ODR of 5000Hz i expected up to 16000 lines.
I tested the modes with 400Hz and 1250Hz and both online-FFT an logged data were right.
If I use the 0.0008s timesteps (1/1250Hz) for the logged 5000Hz-mode before, it looks right...
So theres my question:
Does the Unico GUI only logg data with a rate up to 1250Hz(even in the 5000Hz mode) or could it be a bug in the Unico GUI software?
If I take a look on the wrong online FFT of the GUI, where 600Hz are shown but surely only a 160Hz-signal is given, it looks like that.
Im a little confused.
Thanks for your help!
Greetings,
Markus Schulz
#lis3dh-odr-bandwidth-unico-gui
回帖(2)
曹玥
2019-5-28 15:42:38
嗨马库斯,
我也有同样的问题。您是否已在此方面取得进展或是否已切换到其他传感器?你愿意分享你的发现吗?
亲切的问候,
戴夫
以上来自于谷歌翻译
以下为原文
Hi Markus,
I have the same question. Did you already make progress on this or have you switched to a different sensor? Would you be so kind to share your findings?
Kind regards,
Dave
举报
曾玲娟
2019-5-28 15:59:59
嗨戴夫,
你能不能试试最新版本的Unico软件和FW for STEVAL-MKI109V2。两者都可以找到
http://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-mki109w.html
我现在测试了,我能够以5.376 kHz的频率从LIS3DH记录数据。
以上来自于谷歌翻译
以下为原文
Hi Dave,
can you please try the latest version of Unico software and FW for STEVAL-MKI109V2. Both you can find
.I tested it right now and I'm able to log data from LIS3DH at 5.376 kHz.
举报
更多回帖
