嗨 - 我们尝试了命令,它工作正常。
输入的频率可能超出单位范围。
:FREQuency:FIXed支持所有模型[:SOURce]:FREQuency:FIXed | UP | DOWN [:SOURce]:FREQuency:FIXed?
此命令设置信号发生器输出频率,或增加或减少当前RF频率设置。
频率值。
UP通过第125页上的:FREQuency [:CW]:STEP [:INCRement]命令设置的值增加当前频率设置。前面板向上箭头键执行相同的功能。
DOWN通过第125页上的:FREQuency [:CW]:STEP [:INCRement]命令设置的值减小当前频率设置。前面板向下箭头键执行相同的功能。
要设置频率模式,请参见“:FREQuency:MODE”(第119页)。有关信号发生器频率和功率规格的列表,请参阅第153页上的“[:LEVel] [:IMMediate] [:AMPLitude]”。示例:
FREQ:FIX 10GHZ前面的例子将信号发生器频率设置为10 GHz。
* RST http://cp.literature.agilent.com/litweb/pdf/E8251-90356.pdf问候 -
以上来自于谷歌翻译
以下为原文
Hi -
We tried the command and it works fine. It is possible the entered frequency is exceeding the range on unit.
:FREQuency:FIXed
Supported All Models
[:SOURce]:FREQuency:FIXed |UP|DOWN
This command sets the signal generator output frequency , or increments or decrements the current
RF frequency setting. A frequency value.
UP Increases the current frequency setting by the value set with the
:FREQuency[:CW]:STEP[:INCRement] command found on page 125. The front panel
up arrow key performs the same function.
DOWN Decreases the current frequency setting by the value set with the
down arrow key performs the same function.
To set the frequency mode, see “:FREQuency:MODE” on page 119. For a listing of signal generator
frequency and power specifications, refer to “[:LEVel][:IMMediate][:AMPLitude]” on page 153.
Example
:FREQ:FIX 10GHZ
The preceding example sets the signal generator frequency to 10 GHz.
*RST
Regards -
嗨 - 我们尝试了命令,它工作正常。
输入的频率可能超出单位范围。
频率值。
以上来自于谷歌翻译
以下为原文
Hi -
:FREQuency:FIXed
Example
:FREQ:FIX 10GHZ
*RST
Regards -
举报
