ST意法半导体
直播中
李猛
8年用户 1604经验值
私信 关注
[问答]
LIS3DH高通滤波器不工作
在工作中我使用LIS3DH加速度计来检测身体运动。它配置为+/- 2 gs,每秒50个样本,带有流式FIFO。水印可以很好地确定FIFO何时需要清空。
该规范说明所有三个XY和Z轴都可以使用CTRL_REG2(地址0x21)进行高通滤波,但文档并不完全清楚。我正在向滤波器寄存器写入0x11而没有运气。 HPM1-HPM0设置为1,0。截止频率位设置为0,0应该以每秒50个采样的速率提供1Hz截止频率。
希望有人有关于配置高通滤波器的文档,但我没有。或者有人成功实施了过滤器,可以告诉我他们使用了什么。
#lis3dh-hpfilter
以上来自于谷歌翻译
以下为原文
At work I am using the LIS3DH accelerometer to detect body motion.  It is configured for +/-2 gs, 50 samples per second, with Streaming FIFO.  The watermark works fine for determining when the FIFO needs to be emptied.
The specification says that all three XY&Z axis can be high-pass filtered using CTRL_REG2 (address 0x21), but documentation is not totally clear.  I'm writing 0x11 to the filter register with no luck.   HPM1-HPM0 are set to 1, 0.  The cut off frequency bits are set to 0, 0 which should give a 1Hz cutoff at 50 samples per second.
Hopefully someone has documentation on configuring the high-pass filter that I do not.  Or someone has successfully implemented the filter and can tell me what they used.
#lis3dh-hpfilter
回帖(1)
周丽
2019-5-22 11:30:20
嗨,我遇到了类似的问题。你能正确设置吗?似乎数据表不完整,以便正确设置它。
 你能让我知道如何设置截止频率吗?你怎么知道HPM位的00对应于50个样本的1 hz截止?
 您也知道正常模式与参考信号滤波之间的区别吗?
以上来自于谷歌翻译
以下为原文
Hi, I'm having a similar problem. Were you able to set it up properly? It seems that the datasheet is incomplete in order to properly set it up.
Could you let me know how to set up the cut off frequency? How do you know a 00 for the HPM bits correspond to a 1 hz cut off with 50 samples?
Also do you know the difference between the Normal mode vs the reference signal filtering?
举报
更多回帖
