Microchip
直播中
颜廷波
8年用户 214经验值
私信 关注
[问答]
BM71有什么配置
您好,我们正在研究一个项目,将使用BM71Bluetooth通信模块,我想知道是否有人可以澄清这个模块的两个疑惑:-默认情况下,模块有什么配置(自动操作或手动操作,PIN配置……)?-有什么方法来改变这些设置?-哪些操作允许我运行自动操作模式?提前感谢。
以上来自于百度翻译
      以下为原文
    Hello,
We are working on a project that will use a BM71 bluetooth communications module, I would like to know if anyone could clarify a couple of doubts about this module:
- What configuration does the module have by default (Auto operation or manual operation, pin configuration ...)?
- What methods exist to change these settings?
- What operations allow me to run the auto operation mode?
Thanks in advance.
回帖(3)
王淑英
2019-5-8 12:01:30
对不起,双人邮递。我尝试编辑,并被拒绝访问。这已经是一个错误或董事会一年多了。为什么还没有确定呢?
以上来自于百度翻译
      以下为原文
    Sorry for the double post. I tried editing and got access denied.  This has been a bug or  thus board for over a year.  Why has'not it been fixed yet?
举报
王淑英
2019-5-8 12:13:50
我也在评估这个模块。我在等待一个EVE板到达,所以我也是一个新手。我发现最有用的是秒表演示ProjcTeTTP://MyCHIPSDebug…示例秒表DEWOWHILE这是一个关贸总协定(手动模式)项目,它有一些非常详细的编程配置。我读到BLDK工具是一个Windows工具,允许您配置模块,然后EEPROM实用工具生成一个包含在C代码中的文件,而库代码在启动时将该配置加载到该部分。我认为您需要这样做,即使您使用手动模式,因为您仍然需要将设备名设置为您自己的名称,这样您就可以找到它时,你想连接到它。
以上来自于百度翻译
      以下为原文
    I am also evaluating this module.  I am waiting for an eval board to arrive, so I am also a newbie.   The article I found the most useful is the stopwatch demo project http://microchipdeveloper...example-stopwatch-demo
While this is a GATT (manual mode) project, it has some great detail on programming the configuration.  I read that BLEDK tool is a windows tool the allows you to configure the module, then the EEPROM utility generates a  file which you include in your C code, and the library code loads this configuration into the part on startup.    I think you will need to do this even if you are using manual mode, since you will still need to set the device name to you own name so you can find it when you want to connect to it.
举报
赵静
2019-5-8 12:23:31
感谢帮助,最后我决定使用一个RN48 71U模块,它具有与BM91相同的特性,加上识别ASCII字符,更容易通过微控制器使用。
以上来自于百度翻译
      以下为原文
    Thanks for the help, in the end I decided to use an RN4871U module that has the same features as the BM71 with the addition of recognizing ASCII characters, easier to use through a microcontroller.
举报
更多回帖
