Microchip
直播中
徐丹
8年用户 291经验值
私信 关注
[问答]
无法使用Explorer 16/32 mcp2221a接口芯片
我已经能够连接USB到串行适配器到我的DSPIC33 FJ128GP804 PIM,并发送字符到TyTalm会话。我的USB到串行适配器连接到处理器上的PIN 37,但是,当我使用我的范围来测量在Explorer 16/32上的PIN 50的信号时,我什么也看不见。PIM顶部的跳线位于UART位置。我还尝试删除跳线J37、J38、J42和J42,以确保没有设置错误。谢谢,史葛。
以上来自于百度翻译
      以下为原文
    I've been able to connect a USB to serial adapter to my dsPIC33FJ128GP804 PIM, and transmit characters to a Teraterm session.  My USB to serial adapter is connected to pin 37 on the processor,  However, when I use my scope to measure signals at pin 50 on the Explorer 16/32, I don't see anything.  The jumper on the top of the PIM is in the UART position.  I've also tried removing the jumpers J37, J38, J42, and J42 to make sure that nothing was set incorrectly.
Thanks in advance,
Scott
回帖(9)
刘来有
2019-5-6 13:56:41
你能帮助核实,如果你使用PIM与零件号MA3300 19或MA3300 19-2?HTTP://www. MigCHIPInt.t/CufftSexCH..ASPX?关键字= MA3300 19www. MICCHIP.COM/MA3300 19 www. McCHIP.COM/MA3300 19-2
以上来自于百度翻译
      以下为原文
    can you help verify if you are using PIM with part number MA330019 or MA330019-2 ?
http://www.microchipdirect.com/ProductSearch.aspx?Keywords=MA330019
www.microchip.com/ma330019
www.microchip.com/ma330019-2
举报
李飞
2019-5-6 14:02:27
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
刘来有
2019-5-6 14:11:02
我想你可能已经看了错误的信息表/示意图。如果你在PIC上使用PIN 37,看起来你正在看MA3300 19的示意图,而不是MA3300 19-2。对于MA3300 19-2,应该使用PIC PIN 24为板UART TX.http://WW1.Microchip .com……N/DeviceDoc /51876A.PDF。
以上来自于百度翻译
      以下为原文
    i think you may  have looked at the wrong info sheet/schematic.
If you are using pin 37 on the PIC, it seems you were looking at the schematic for MA330019 and not MA330019-2.
For MA330019-2, should be using PIC pin 24 for board UART TX...
http://ww1.microchip.com/...n/DeviceDoc/51876A.pdf
举报
李飞
2019-5-6 14:18:49
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
更多回帖
