出现了两个版本的创建者2和2.1之间的差异列表,因此可以更容易地跟踪所有更改,其中一些在第一次菜单或标签中不可见。
2和2.1是共存的,这意味着您可以同时使用这两个,但是您应该避免访问具有不同版本的相同项目,因为项目的内部结构不同。已经保存了2.1下的项目,它可能不会再次打开2,尽管有一个备份被创建(当用2.1打开时),您可以从2重新启动它。
更新项目的组件覆盖项目的组件,而不是组件列表中的组件。
不更新组件将使您的项目与旧版本一样。
我总是建议使用最新版本的组件,有时会有讨厌的bug被删除。看看下面的数据表,(到最后)是一个到目前为止的变化列表。
鲍勃
以上来自于百度翻译
以下为原文
There comes a list of differences between the two versions Creator 2.0 and 2.1, so it can be much easier to follow up all the changes where some of them are not visible in a menu or tab at first sight.
2.0 and 2.1 are co-existent, that means you can use both at the same time, but you should avoid accessing the same project with different versions because the internal structure of a project differs. Having saved a project under 2.1 it may not be opened again with 2.0 although there has a backup been created (when opened with 2.1) from which you may re-start with 2.0.
Updating components for a project overwrites the PROJECT's components, not those in your component list.
Not updating components will leave your project as-it-is with the older versions.
Bit I would always suggest to use the latest version of a component, sometimes there are nasty bugs removed. Have a look into the according datasheets, there (at the very end) is a list of changes made so far.
Bob
不更新组件将使您的项目与旧版本一样。
鲍勃
以上来自于百度翻译
以下为原文
Bob
举报
