是德科技
直播中
h1654155275.5814
8年用户 216经验值
私信 关注
[问答]
PXA/MXA驱动器的大小是多少?
我们正在购买几个备用SSD驱动器,以支持我们的PNA和PNA-X系统。
我们的采购部门将订购60 GB驱动器,因为早期的PNA和PNA-X系统使用40 GB驱动器,但较新的系统有80 GB驱动器。
我的问题是,这些较新的系统上的图像是使用整个驱动器还是仍然是40 GB?
在单独的说明中,可能属于另一个论坛,PXA / MXA驱动器的大小是多少?
如果我们能够购买可以支持我们所有系统的备用驱动器,那就太棒了。
Spacecase
以上来自于谷歌翻译
     以下为原文
  We are purchasing several spare SSD drives to support our PNA and PNA-X systems. Our purchasing department was going to order 60 GB drives since the early PNA and PNA-X systems used 40 GB drives, however the newer systems have 80 GB drives. My question is, do the images on these newer sysems use the entire drive or are they still 40 GB?
On a separate note, and possibly belonging in another forum, what size are the PXA/MXA drives? It would be great if we could purchase spare drives that could support all of our systems.
Spacecase
回帖(1)
陈建华
2019-4-30 11:32:08
对于较新的PNA,我们建议使用80GB(或更大)的驱动器,但是60的驱动器也能正常工作....你只是没有足够的空间存放用户文件。
如果您计划切换到Windows 7(一旦我们推出它),那么额外的空间将是不错的。
请注意,Win7仅适用于物理尺寸更大的PNA。
以上来自于谷歌翻译
     以下为原文
  We would recommend 80GB drives (or larger) for newer PNAs, but 60's would work just fine too....you just will not have as much room for user files.
If you are planning on ever switching over to Windows 7 (once we come out with it), then the extra space would be nice.
Please note that Win7 will only be available for PNAs with the physically larger displays.
举报
更多回帖
