Microchip
直播中
郑尧
7年用户 202经验值
私信 关注
[问答]
和声代码中的语法错误
我想在我的项目中添加AppIO。它失败了。AppIO系统根本不起作用。它甚至不允许SysSoSoeleSimult.c编译。下面的函数更改会修复编译问题。BUF的演员做得不正确。之后,Appo仍然不起作用。这是关于和谐2Y02Y100B和MPLABX 3.51和XC32 1.42i开始与USB鼠标演示。并遵循了“简单”调试指令中的热点!解决:在MPLAB X IDISSIZEZT SysSconSoeleRead(const SysMuleEndex index index,int fd,Vult*Buf,SiZeStt计数){sisixt NUMLUTB=0;dBGET((char *)BUF,128);同时(*(char *)(BUF)+NUBEnter);= LynPiFor){NuthByth++;}返回计数;}
以上来自于百度翻译
      以下为原文
    I'm trying to add APPIO to my project.  It fails.
The APPIO system doesn't work at all.  It does not even allow the sys_console_static.c to compile.
The function change below fixes the compile problem.  the cast of buf was done incorrectly.
After that APPIO still doesn't work.  This is on hARMony 2_02_00b and MPLABX 3.51 and XC32 1.42
I started with the USB mouse demo.  and followed the "simple" debug instructions in the
Hot!Solved: The ABSOLUTE simplest way to set up a AppIO Console Debug Session in MPLAB X IDE
ssize_t SYS_CONSOLE_Read(const SYS_MODULE_INDEX index, int fd, void *buf, size_t count )
size_t numBytes = 0;
DBGETS ((char*)buf, 128);
while ( *((char *)(buf) + numBytes) != LINE_FEED )
numBytes++;
return count;
回帖(13)
曾佳宁
2019-4-28 13:12:31
哦,修复这个问题后,AppIO菜单项就变灰了。
以上来自于百度翻译
      以下为原文
    OH, the issue after fixing this is that the APPIO menu item is greyed out.
举报
王焕树
2019-4-28 13:25:06
为什么这个函数返回它的一个参数?当然,返回NUMBULL会更有用。
以上来自于百度翻译
      以下为原文
    Why on earth is that function returning one of its parameters?
Surely it would be more useful to return numBytes.
举报
陈晨
2019-4-28 13:32:30
这一个怎么样:我猜他们一段时间重写了部分内容,没有测试其余的构建选项。只是在样例应用程序中使用的那些选项。
以上来自于百度翻译
      以下为原文
    How about this one:
    return numBytes;
I guess they rewrote part of it a while back and did not test the rest of the build options.
Just the ones used in the Sample Applications.
举报
王焕树
2019-4-28 13:38:06
我假设“计数”是指所提供的缓冲区的大小,在这种情况下,这条线应该是
以上来自于百度翻译
      以下为原文
    I'm assuming "count" is meant to be the size of the supplied buffer, in which case, this line
should have been
DBGETS ((char*)buf, count);
举报
更多回帖
