你好!阿南德!
谢谢你的回答!
我发现这个社区有人说,Windows XPU的UB3.Sys2可能不支持批量流,并且我还发现CyPress FX2SDK的示例CyfxBulkFipe不能正常工作,我想它不能成功枚举,因为我看不到任何设备信息、接口和EndoPo。下载后的USB控制器中心。
SRRY没有清楚地知道关于MyStand配置的任何说法,对于TRAM中的4,我在EP中用4个流配置端点AS1块,EP同伴描述符中的流是2(2 ^ 2=4)。我还配置了具有相同回调函数的4个DMA通道,我只是参考CyfxBulkFielsFask的所有内容。
对于主机控制器,我不确定哪一个是主控制器,有两个,ASMIXHCI控制器和标准增强PCI到USB主机控制器。
以上来自于百度翻译
以下为原文
Hi! Anand!
thx for ur answear!
I found that someone at this community said the u***3.sys of windows xp maybe not support the bulk streams, and I also identified the example cyfxbulkstreams from CYPRESS FX2 SDK can not work normally,I suppose it can not enumerate successfully because I can not see any device info ,interface,and endpoints in USB controller center after download.
srry about no understanding what u said about my setup configuration clearly, for 4 IN treams, I config the endpoint as 1 bulk IN ep with 4 streams ,and the streams in ep companion descriptor is 2(2^2=4) . I also config the 4 DMA channels with the same callback function, I just do everything referring the cyfxbulkstreams example .
For host controllor , I m not sure which is the propor one, there are two ,ASMedia XHCI Controller and Standard Enhanced PCI to USB Host Controller.
你好!阿南德!
谢谢你的回答!
以上来自于百度翻译
以下为原文
Hi! Anand!
thx for ur answear!
举报
