你好,
我正在尝试使用SPC5-UDESTK在安装在SPC560BADAPT144S评估板上的SPC560B60L5上运行测试应用程序(SPC560Bxx OS-Less测试应用程序)。
生成并构建测试应用程序后,我尝试通过按下hte调试按钮进行连接,但它表示启动失败,未找到二进制文件。
在创建“C / C ++应用程序”调试配置并将其指向构建目录中的out.elf文件后,我仍然无法连接错误:
启动命令时出错:gdb --version。
我的SPC5安装中是否有任何遗漏?
还有,有人可以指点我一步一步的教程应用笔记吗?我无法在ST的网站上找到一个。
提前致谢。
以上来自于谷歌翻译
以下为原文
Hi there,
I am trying to run a test applica
tion (SPC560Bxx OS-Less test application) on SPC560B60L5 mounted in SPC560BADAPT144S evaluation board, using SPC5-UDESTK.
After generating and building the test application I am trying to connect by pressing hte debug button, but it says that launch failed, binary not found.
After creating a ''C/C++ Application'' debug configuration and pointing it at the out.elf file in the build directory, I am still failing to connect with the error:
Error while launching command: gdb --version.
Is there anything missing in my SPC5 installation?
Also, could someone point me at a step by step tutorial application notes? I was unable to find one in ST's site.
Thanks in advance.
