Cypress技术论坛
直播中
朱梁贡
7年用户 207经验值
私信 关注
[问答]
模拟模块之间的内部路由疑问
HI开发者,
我有关于内部路由两个模拟模块之间通过端口引脚的疑问。可以是任何引脚配置为模拟模块的输出,也可以作为其他模块的输入?换句话说,它的“驱动”的设置是“强”的同时,其“选择”设置为“模拟”
例如,端口0引脚5可同时缓冲输出引脚可以用于另一个PGA输入端?
以上来自于百度翻译
     以下为原文
   hi developers,
                                     i have a doubt regarding internal routing between two analog modules through port pins. can any pin which is configured as an analog module's output can also be used as an input to other module? in other words can its "drive" setting be "strong" and simultaneously its "select" setting be "analoginput"
    for example the port 0 pin 5 can be an output pin from a buffer at the same time can it be used in the input side of another PGA ?
回帖(2)
王琳
2019-4-19 08:39:00
您可以将输出设置为“强”,同时将其定义为模拟输入。问题是:这有道理吗?模拟输入(PGA)将“看到”引脚上的电压,这是一个数字(输出)信号,并具有其定义的电压电平。
那么,你想完成什么呢?还是只是一个理论问题?记住,使用内部路由,当然可以生成快捷方式和其他非常不可用的配置。
快乐路由
鲍勃
以上来自于百度翻译
     以下为原文
  You may set the output to "strong" and define it as analog input at the same time. The question is:does that make sense? The analog input (your PGA) will "see" the voltage on the pin, which is a digital (outputted) signal and has its defined voltage-levels.
    So, what do you want to accomplish or is it just a kind of theoretical question? Keep in mind, that with the internal routing you may of course generate shortcuts and other quite unusable configurations.
    Happy routing
    Bob
举报
朱梁贡
2019-4-19 08:45:04
嗨,鲍伯,
关于这个项目的疑虑来自峰值保持。在这个项目中看到端口0引脚4。它同时充当输出和输入。
以上来自于百度翻译
     以下为原文
   hi bob,
                   The doubt arised from this project regarding peakholding. in this project see the port 0 pin  4. which acts as an output and as an input at the same time.
举报
更多回帖
