赛灵思
直播中
李宸如
7年用户 174经验值
私信 关注
[问答]
寻求为FIR滤波器实现无乘法器的乘法器
大家好,如果这是错误的论坛,请道歉,如果有人指向正确的论坛,我将不胜感激。
免责声明:我是VHDL的新手。
我正在寻求为FIR滤波器实现无乘法器的乘法器。
我想尽可能地做到一般,所以我不想硬编码我的组件展示位置。
是否有一种程序生成组件的好方法(即乘数)?
我在CSD中编码了常数被乘数的数字,并将其存储为字符串,我通过'generic'语句将其传递给组件。
现在我试图使用生成循环(循环遍历字符串)来放置加法器,减法器和移位器。
问题是一个加法器/减法器的输出直接输入到下一个输入器的输入端,由于存在未知数量的加法器,我不能事先声明信号。
最好的方法是什么?
以上来自于谷歌翻译
以下为原文
Hi all, apologies if this is the wrong forum for this, it would be much appreciated if someone could point toward the right one.
Disclaimer:  I'm new to VHDL.
I'm looking to implement a multiplier-less multiplier for an FIR filter.  I'm trying to be as general as possible, so I don't want to hard-code my component placements.  Is there a good method of procedurally generating a component (i.e. a multiplier)?  I've encoded the digits of the constant multiplicand in CSD and stored it as string which I'm passing into the component via a 'generic' statement.  Now I'm attempting to use a generate loop (looping over the string) to place adders, subtractors, and shifters.  The issue is that the output of one adder/subtractor is piped directly into the input of the next one and since there is an unknown amount of adders, I can't declare the signals before hand.  What's the best way to go about this?
回帖(2)
陈鲜孰
2019-4-19 07:14:06
您可以使用数组声明“通用”数量的信号。
如果每个阶段都有共同的信号,则记录数组会有所帮助。
即:
输入my_signals是记录
i,q:签名(31 downto 0);
结束记录;
type my_signal_array是my_signals的数组(自然范围);
signal z:my_signal_array(0到GENERIC_VALUE);
z(0).I clk,real_in => z(n).i,imag_in = z(n).q,real_out => z(n + 1).I,imag_out => z(n + 1).q
结束生成;
use_block_B:如果不是use_block_A生成
INST:BLOCK_B(clk => clk,real_in => z(n).i,imag_in = z(n)。q,real_out => z(n + 1).I,imag_out => z(n + 1)。
q);
结束生成;
结束生成; I_out q_out
无论如何,这是个主意。
“z”信号在体系结构中声明(不在生成内部),因此它对生成块是全局的。
以上来自于谷歌翻译
以下为原文
You can declare a "generic" number of signals using arrays. An array of records helps if there are common bundle of signals for each stage. i.e.:
type my_signals is record    i,q : signed(31 downto 0);end record;type my_signal_array is array(natural range <>) of my_signals;signal z : my_signal_array(0 to GENERIC_VALUE);.....z(0).I <= some_input..;z(0).q <= some_input...; stages : for n in z'range generatebegin      use_block_A : if use_block_A generate           INST : BLOCK_A ( clk => clk, real_in => z(n).i, imag_in = z(n).q  , real_out => z(n+1).I , imag_out => z(n+1).q  );      end generate;
      use_block_B : if not use_block_A generate           INST : BLOCK_B ( clk => clk, real_in => z(n).i, imag_in = z(n).q  , real_out => z(n+1).I , imag_out => z(n+1).q  );      end generate;end generate;
I_out <= z(GENERIC_VALUE).I;
q_out <= z(GENERIC_VALUE).q;
 Anyway that's the idea.  The "z" signal is declared in the architecture (not inside the generate), so that it is global to the generate blocks.
举报
陈晨
2019-4-19 07:33:26
谢谢!
这非常有帮助!
以上来自于谷歌翻译
以下为原文
Thanks!  This was very helpful!
举报
更多回帖
