嗨西蒙,非常感谢您的及时回复,但是,整个上午我都花了很多时间来尝试实施您的指示。
我在外部触发输入上尝试了几个源,并验证输入实际上是作为外部触发器工作。
所有尝试包括最后一次使用外部触发的81104A设置为TTL o / p。
在中心屏幕上没有出现“执行时基对齐”。
它只是显示当前的DAC值,可以使用RPG上下移动。
我觉得您的指令缺少步骤或服务密码可能需要允许例程运行或允许DACS上的写入启用。
我尝试了一些服务密码尝试,MXA,ESA和PSA不起作用。
如果有什么遗失的话,你可以再看一眼我的指示吗?
亲切的问候,安迪
以上来自于谷歌翻译
以下为原文
Hi Simon,
Many thanks for your prompt reply, however, all morning I've spent trying to implement your instructions without any success.
I've tried several sources on the external trigger input and verified that the input actually works as an external trigger.
All attempts including the last using an externally triggered 81104A set to TTL o/p. At no point has the "Doing Timebase Alignment" appeared at centre screen. It just sits showing the current DAC value which can be moved up and down with the RPG. I feel your instructions are missing a step or a service password may be needed to allow the routine to run or allow a write enable on the DACS. I've tried a few service password attempts, MXA, ESA and PSA ones don't work.
Could you have another glance over your instructions for me just in case there is something missing.
Kind regards,
Andy
在中心屏幕上没有出现“执行时基对齐”。
亲切的问候,安迪
以上来自于谷歌翻译
以下为原文
Hi Simon,
Kind regards,
Andy
举报
