Microchip
直播中
王官君
8年用户 153经验值
私信 关注
[问答]
PICKIT3不识别pic12f1572
您好,我有一个紧迫的项目,我需要交付,我需要论坛成员和微芯片AssiPress解决PICIT3和PIC12F1572之间的错误连接问题。由于皮卡3没有识别/识别这个模型。IsErrad的Web和没有找到任何实际的解决方案,这个问题只是MPLAB解决方案没有相关,因为这是我们如何建立这个SW项目,不知道我们将无法直接连接通过PICtiT3程序员Bur1529 7148!PICIT3和其他PIC一样,像16F5853和其他模型一样伟大,但是当我连接1572,它甚至没有检测到它-我尝试通过手动搜索和切换所有的家庭,我不知道如何解决这个问题-我认为MICCHIPSTeP有解决方案,但没有看到它在网络上。请伸出援助之手。
以上来自于百度翻译
      以下为原文
    Hello,
I have an urgent project I need to deliver and I need the forum members and microchip Assitance to solve the misconnection issue between Picit3 and pic12f1572. As the pickit 3 doesn't recognize/ identify this model. I searched the web and didn't found any practical solution for this issue Only MPLAB solutions which are not relevant because this is how we build this sw project and didn't know we will not be able to connect directly via PICKIT3 PROGRAMMER BUR152974148!
The PICIT3 works Great with other pic's like 16f583 and other models but when I connect the 1572 it doesn't even detect it - I tried by manual search and switched all families and I don't know how to solve this issue - I think Microchip team have the solution but didn't saw it on the web.
Appreciate In Advance your assistance.
回帖(19)
陈晨
2019-4-8 10:55:57
这不是从Microchip获得帮助的最佳场所。你没有清楚地陈述你的问题,所以我怀疑你会从用户那里得到很多帮助。你的“解决方案”是不清楚的。一个皮克特3和MPLabX会跟PICSo说话,你用的是没有MPLab的皮卡3?怎么用?固件的版本是什么?它是怎么到达那里的?它是否足够新来知道如何与新芯片对话?
以上来自于百度翻译
      以下为原文
    This is not the best place to get help from microchip.
You did not clearly state your problem so I doubt you will get much help from users.
Your "solution" is un clear.
A pickit3 and MPLabX will talk to that PIC
So you are using a pickit3 without MPLab?
How?
What version of firmware is on it? How did it get there? Is it new enough to know how to talk to the newer chip?
举报
吕聪
2019-4-8 11:11:41
OP可能使用PK3独立应用程序(脚本工具)。@ BARG,也许您可以试试PK2DEVICEFIL.DAT HETPSPS://GITHUB.COM/GBED/……/MST/PICIT2/PK2DFT
以上来自于百度翻译
      以下为原文
    The OP might use the PK3 standalone application (scripting tool).
@barg, maybe you can try the PK2DeviceFile.dat here
https://github.com/GBert/.../master/pickit2/pk2dft
举报
谢微微
2019-4-8 11:23:15
你好,谢谢你的回复。我用PICTIT3作为独立的程序员,PICTIT3版本是BUR15247148,意思是,我把代码上传到应用程序并把它烧到集成电路上。这种编程方式会烧毁16F1933和其他PIC。因为PICIT3版本没有更新,所以我没有找到12F1572的问题,我试图在网络中找到几天,但是找不到,所以我需要一个更新的3版本,可以检测到1572。至于MPLAB,我使用CCS C com。PILER和只使用PICIT3在PIC MCU上导入HEX文件。请建议我在哪里可以找到一个解决方案,如果这不是正确的论坛/地方?因为我不太熟悉这个论坛。
以上来自于百度翻译
      以下为原文
    Hi,
Thank you for your reply.
I use the pickit3 as a STAND ALONE PROGRAMMER, the pickit3 version is BUR152974148, meaning, I upload the code to the application and burn it to the ic. this way of programming burn 16f1933 and other pic's. the problem it doesn't detect the 12f1572 because the picit3 version is not updated and I tried to find in the web for a few days and couldn't find so I need an updated version of the pickit 3 that can detect the 1572.
As to MPLAB - I use CCS C Compiler And Use only the PICIT3 to import hex file on the pic mcu's.
Please advice where can I find a solution if this not the right Forum/place? as I am not oftenly familiar with this forum.
Regards
举报
汤赫禧
2019-4-8 11:31:08
嗨,Timijk,谢谢你的提议,我检查了你发送的列表,上面显示了PIC12F1572,但是我在哪里找到这个安装到PICTIT3的版本?我有1572和PICIT3会说话吗?
以上来自于百度翻译
      以下为原文
    Hi Timijk,
Thanks for the offer, I checked the list you sent and the pic12f1572 is shown over there but where do I find this version to install to the picit3 i have that the 1572 and picit3 will talk?
举报
更多回帖
