嗨,我终于连接了传感器。你能来吗?解释以下结果:
第一个数字是iOS App上的“接收时间戳”,第二个是节点时间戳,第三个是值(加速器Z)。
我假设节点时间戳也是以毫秒为单位(对吗?)。你说采样率是104Hz - > 1/104大约是9毫秒,这是对的。
但是接收到的时间戳给出了30到60毫秒等事件之间的间隔,这是毫秒级的官方系统源。但是两者都不匹配!可能是节点时间戳是10秒,如果毫秒?那么时间戳会匹配,但我们会得到大约60毫秒的采样率!
以上来自于谷歌翻译
以下为原文
Hi, I have finally attached the sensor. Could you pls. explain the following results:
First number is the 'receiving timestamp' on iOS App, second is the Node Timestamp, third the value (Accelerator Z).
I assume the node timestamp is also in Miliseconds (right?). You said sample rate is 104Hz -> 1/104 is about 9 ms which is right.
But the the received timestamp gives interval between events like 30 ... 60 ms and this is the official system source for miliseconds. But then both do not match! Could it be that the Node timestamp is in 10th if miliseconds? Then the timestamps would match but we will get the sample rate of about 60 ms!
以上来自于谷歌翻译
以下为原文
举报
