MSP430技术论坛
直播中
王宇
7年用户 140经验值
私信 关注
[问答]
msp430f1611驱动正点2.8寸ili9341的屏幕没有找到原函数
首先,我看初始化那里ili9341有很多初始化程序,有LG 2.8” Initial Code, BOE 2.0” INITIAL CODE ,BOE 2.4” INITIAL CODE ,BOE 2.4” INITIAL CODE。。。。TM2.8INCH INITIAL CODE,正点的到底用那个?还有初始化程序中的
LCD_ILI9341_CMD(0xCB);  LCD_ILI9341_ Parameter (0x39);
这些应该是调用函数,但是我没有找到原函数,
还有是不是不初始化,屏幕及时接上电也不会亮。
回帖(1)
潘务单
2019-4-2 10:59:06
你直接用我们提供的例程即可啊。
9341初始化代码:
if(lcddev.id==0X9341)//9341初始化
LCD_WR_REG(0xCF);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0xC1);
LCD_WR_DATA(0X30);
LCD_WR_REG(0xED);
LCD_WR_DATA(0x64);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0X12);
LCD_WR_DATA(0X81);
LCD_WR_REG(0xE8);
LCD_WR_DATA(0x85);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x7A);
LCD_WR_REG(0xCB);
LCD_WR_DATA(0x39);
LCD_WR_DATA(0x2C);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x34);
LCD_WR_DATA(0x02);
LCD_WR_REG(0xF7);
LCD_WR_DATA(0x20);
LCD_WR_REG(0xEA);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_REG(0xC0);    //Power control
LCD_WR_DATA(0x1B);   //VRH[5:0]
LCD_WR_REG(0xC1);    //Power control
LCD_WR_DATA(0x01);   //SAP[2:0];BT[3:0]
LCD_WR_REG(0xC5);    //VCM control
LCD_WR_DATA(0x30);  //3F
LCD_WR_DATA(0x30);  //3C
LCD_WR_REG(0xC7);    //VCM control2
LCD_WR_DATA(0XB7);
LCD_WR_REG(0x36);    // Memory Access Control
LCD_WR_DATA(0x48);
LCD_WR_REG(0x3A);
LCD_WR_DATA(0x55);
LCD_WR_REG(0xB1);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x1A);
LCD_WR_REG(0xB6);    // Display Function Control
LCD_WR_DATA(0x0A);
LCD_WR_DATA(0xA2);
LCD_WR_REG(0xF2);    // 3Gamma Function Disable
LCD_WR_DATA(0x00);
LCD_WR_REG(0x26);    //Gamma curve selected
LCD_WR_DATA(0x01);
LCD_WR_REG(0xE0);    //Set Gamma
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x2A);
LCD_WR_DATA(0x28);
LCD_WR_DATA(0x08);
LCD_WR_DATA(0x0E);
LCD_WR_DATA(0x08);
LCD_WR_DATA(0x54);
LCD_WR_DATA(0XA9);
LCD_WR_DATA(0x43);
LCD_WR_DATA(0x0A);
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_REG(0XE1);    //Set Gamma
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x15);
LCD_WR_DATA(0x17);
LCD_WR_DATA(0x07);
LCD_WR_DATA(0x11);
LCD_WR_DATA(0x06);
LCD_WR_DATA(0x2B);
LCD_WR_DATA(0x56);
LCD_WR_DATA(0x3C);
LCD_WR_DATA(0x05);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x0F);
LCD_WR_DATA(0x3F);
LCD_WR_DATA(0x3F);
LCD_WR_DATA(0x0F);
LCD_WR_REG(0x2B);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x3f);
LCD_WR_REG(0x2A);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0xef);
LCD_WR_REG(0x11); //Exit Sleep
delay_ms(120);
LCD_WR_REG(0x29); //display on
举报
更多回帖
