您好,我有以下配置:MPLAB X IDE V3.60xC16(V1.31)DSIC33 EP256MC204MCC V3.2264I不能将PMOD位注册为01(PWMX I/O引脚对是冗余输出模式)。MCC上有两个通道,启用或禁用。当设置为启用时,设置为DAB时设置为0B11。LED,设置为0B00
以上来自于百度翻译
以下为原文
Hello,
I have the following configura
tion:
MPLAB X IDE v3.60
XC16 (v1.31)
dsPIC33EP256MC204
MCC v3.26.4
I can not set IOCONx register' PMOD bits to 01 (PWMx I/O pin pair is in the Redundant Output mode)
There are two chooices on MCC, enabled or disabled.
When set to enabled, it is set to 0b11
When set to disabled, it is set to 0b00
