嗨,
我目前正在尝试将Mo
tionEC库用于E-Compass应用程序,并使用MotionMC库校准磁力计。我正在使用带有LSM303AGR的
STM32L1-DISCO。我的一般想法是运行校准算法x秒,然后获取校准参数,并将它们应用于
电子罗盘计算。
MotionEC库工作得非常好,但我遇到了MotionMC库的麻烦。
首先,我正在运行MotionMC_Update函数,其中包含我从磁力计读取的参数。之后,我正在调用MotionMC_GetCalParams来获取校准参数。但是库总是返回以下默认值:
HI_Bias = {0,0,0},
SF_Matrix = {{1,0,0},{0,1,0},{0,0,1}},
CalQuality = MMC_CALQSTATUSUNKNOWN
这是我的代码(基于ST示例)。
// COMPASS_REPORT_INTERVAL = 20
//每隔20ms调用一次
void doCalibrationStep()
SensorAxes_t mag_data_uncompensated;
getMagneto(安培; mag_data_uncompensated); MMC_Input_t data_in;
data_in.Mag [0] =(float)mag_data_uncompensated.AXIS_X / 10.0f;
data_in.Mag [1] =(float)mag_data_uncompensated.AXIS_Y / 10.0f;
data_in.Mag [2] =(float)mag_data_uncompensated.AXIS_Z / 10.0f; data_in.TimeStamp = timestamp * COMPASS_REPORT_INTERVAL;
//示例data_in:Mag = { - 64,5.5,17.1000004},TimeStamp = 0
MotionMC_Update(安培; DATA_IN); MMC_Output_t data_out;
MotionMC_GetCalParams(安培; DATA_OUT); dbg('CalParams X:%f,Y:%f,Z:%f,质量:%d r n',data_out.HI_Bias [0],data_out.HI_Bias [1],
data_out.HI_Bias [2],data_out.CalQuality); //无论我多久运行算法时间戳++,一切都有默认值;
void doCalibration()
MotionMC_Initialize(COMPASS_REPORT_INTERVAL,1);
char lib_version [200]; MotionMC_GetLibVersion(lib_version);
DBG(lib_version); //这里打印正确的版本< doCalibrationStep()以20ms的间隔重复调用,直到x秒过去>
MotionMC_GetCalParams(安培; cal_params); //所有参数均为零
我完全不知道什么是错的。我错过了什么吗?
谢谢
以上来自于谷歌翻译
以下为原文
Hi,
I'm currently trying to use the MotionEC library for an E-Compass application, and to calibrate the Magnetometer with the MotionMC library. I'm using an STM32L1-DISCO with an LSM303AGR. My general idea is to run the calibration algorithm for x seconds, then get the calibration parameters, and apply them to the e-compass calculation.
The MotionEC library works perfectly fine but I ran into troubles with the MotionMC library.
At first, I'm running the MotionMC_Update function with the parameters I'm reading from the Magnetometer. After that, I'm calling MotionMC_GetCalParams to get the calibration parameters. But the library is always returning the following default values:
HI_Bias = {0, 0, 0},
SF_Matrix = {{1, 0, 0}, {0, 1, 0}, {0, 0, 1}},
Here is my code (based on the ST examples).
// gets called every 20ms
getMagneto(&mag_data_uncompensated); MMC_Input_t data_in;
data_in.Mag[0] = (float) mag_data_uncompensated.AXIS_X / 10.0f;
data_in.Mag[1] = (float) mag_data_uncompensated.AXIS_Y / 10.0f;
data_in.Mag[2] = (float) mag_data_uncompensated.AXIS_Z / 10.0f; data_in.TimeStamp = timestamp * COMPASS_REPORT_INTERVAL;
// example data_in: Mag = {-64, 5.5, 17.1000004}, TimeStamp = 0
MotionMC_Update(&data_in); MMC_Output_t data_out;
MotionMC_GetCalParams(&data_out); dbg('CalParams X: %f, Y: %f, Z: %f, Quality: %drn', data_out.HI_Bias[0], data_out.HI_Bias[1],
data_out.HI_Bias[2], data_out.CalQuality); // everything has default values, no matter how often I run the algo timestamp++;
MotionMC_Initialize(COMPASS_REPORT_INTERVAL, 1);
char lib_version[200]; MotionMC_GetLibVersion(lib_version);
dbg(lib_version); // here the correct version is printed
MotionMC_GetCalParams(&cal_params); // all parameters are zero
I have absolutely no clue what's wrong. Do I miss something?
Thanks
