赛灵思
直播中
张新里
8年用户 186经验值
私信 关注
[问答]
用于Micron闪存的vivado工具怎么设置
嗨,
你能告诉我在闪存存储器MT29F1G08ABADAWP-IT:D的vivado工具中设置的设置,来自制造商Micron与Xilinx Zynq Soc XC7Z020-2CLG400I一起使用。
该闪存被用作启动源,并连接到SoC的PS部分中的专用I / O.
谢谢,
Vasanthan N.
以上来自于谷歌翻译
以下为原文
Hi,
Can you please let me know the settings to be set in vivado tool for the flash memory MT29F1G08ABADAWP-IT:D from the manufacturer Micron used with the Xilinx Zynq Soc XC7Z020-2CLG400I.
This flash is being used as the boot source and is connected to the dedicated I/Os in PS Section of SoC.
Thanks,
Vasanthan N
回帖(1)
王山崎
2019-3-27 10:27:13
嗨,请参考UG908的“编程配置存储器设备”部分,使用启动映像(包含FSBL,位文件(可选)或任何应用程序)对闪存进行编程。一旦编程了闪存,就可以通过它启动Zynq
设置相应的引导模式引脚设置(参见Zynq TRM(UG585)的第6章)。问候,Krishna
---------------------------------------------请将帖子标记为
如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
Please refer to "Programming a Configuration Memory Device" section of UG908 to program the flash with the boot image (containing FSBL, bit file (optional) or any applications).
Once the flash is programmed, you can boot Zynq from it by setting the appropriate boot strap mode pin settings (refer to chapter 6 of Zynq TRM (UG585)).
Regards,
Krishna-----------------------------------------------------------------------------------------------
Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue.
Give Kudos to a post which you think is helpful.
举报
更多回帖
