ST意法半导体
直播中
李天氍
7年用户 252经验值
私信 关注
[问答]
怎么使用L298和L297进行步进控制
大家好,我的名字是Cosimo,我需要有关步进驱动程序的帮助。
从一台旧打印机我得到了一个双极步进器,现在我正试图用L298和L297配置驱动它。步进输出,L298的输出为:0V 12V 0V 12V。没关系!但是对于电机,L298的输出为:6V 6V 6V 6V。为什么这个?
测试L297输出我没有电机:引脚4 0V,引脚6 4.4V,引脚5 4.4V,引脚7 0V,引脚9 4.4V,引脚8 4.4V。
测试L297输出我用电机:引脚4 0V,引脚6 4.4V,引脚5 2.2V,引脚7 0V,引脚9 4.4V,引脚8 2.2V。
提前致谢。
科西莫
#L298-L297
以上来自于谷歌翻译
以下为原文
Hi to all, my name is Cosimo and I need help about stepper driver.
From an old printer I've get a bipolar stepper and now I'm trying to drive it with L298 and L297 configuration. Whitout the stepper the output of L298 are: 0V 12V 0V 12V. It's ok! But with the motor the output of L298 are: 6V 6V 6V 6V. Why this?
Testing the L297 output I've without the motor: pin 4 0V, pin 6 4.4V, pin 5 4.4V, pin 7 0V, pin 9 4.4V, pin 8 4.4V.
Testing the L297 output I've with the motor: pin 4 0V, pin 6 4.4V, pin 5 2.2V, pin 7 0V, pin 9 4.4V, pin 8 2.2V.
Thanks in advance.
Cosimo
#l298-l297
回帖(3)
李天氍
2019-3-25 09:48:19
解决了!当启动条件为0101且步进电压为12V时,步进电压为6V是正常的..问题是电路板(驱动器L297 + L298和PIC32入门工具包)之间的接地连接和时钟速度为高...感谢所有。
以上来自于谷歌翻译
以下为原文
solved! 6V are normal in stepper when the start condition is 0101 with 12V supply of stepper.. the problem was ground connection between boards (driver L297+L298 and PIC32 starter kit) and clock speed to high.. thanks to all.
举报
吴南加
2019-3-25 09:57:51
我是一名电气工程专业的学生。我只想问是否需要将光隔离器与L298连接?它没有内置保护吗?
 我正在使用带有NXT乐高电机的STM32F303微控制器。电机规格如下:
失速电流:2A
自由运行电流:60mA
以上来自于谷歌翻译
以下为原文
I am an Electrical Engineering student. I just wanna ask whether is there any need to connect optoisolator with L298? Doesn't it has built in protection?
I am using STM32F303 microcontroller with NXT lego motors. Specs of motors are:
Stall current: 2A
Free running current: 60mA
举报
刘璐
2019-3-25 10:17:19
嗨,
通常在这种应用中不需要光隔离器。 L298集成了热保护功能,您指出的电流额定值均在IC的安全范围内。
恩里科
以上来自于谷歌翻译
以下为原文
Hi,
Usually optoisolator are not required in this kind of applications. The L298 integrates thermal protection and the current ratings you indicated are within the safety ranges of the IC.
Enrico
举报
更多回帖
