ST意法半导体
直播中
李裕伦
8年用户 183经验值
私信 关注
[问答]
L6206可以用作4个半H桥吗?
我想用L6206驱动4个螺线管(螺线管的一端,每个螺线管将接地),每个螺线管为2.5安培。这可以在不损坏IC的情况下完成。 ?此外,每个桥梁的两半都不会同时被驱动。意味着第一个桥上的2个电磁阀只能交替使用,不能同时使用。可以这样做吗?
如果同时打开两个桥接器,数据表说它的输出引脚上会有Vs,我有一个问题,即如果这种情况不会发生,那么电路的可靠性就会受到影响。
谢谢
以上来自于谷歌翻译
以下为原文
I want to use the L6206 to drive 4 solenoids (one end of the solenoid each solenoid will be grounded) of 2.5amps each. Can this be done without damaging the IC. ? Also each of the bridges two halfs will not be drived simultaneously. Means the 2 solenoids on 1st bridge will be used only alternatively and never simultaneously. Can this be done?
In a case if both bridges are simultaneously turned on the data sheets says it will have Vs on its output pins, I had a question if this condition though it would not ever occur would be bad for the circuit reliability.
Thanks
回帖(1)
张秀兰
2019-3-21 12:41:23
再见
 我建议将这个问题发布在https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx
论坛。
 谢谢
 再见
 梁咏琪
 注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
Ciao
I suggest to post this question in the https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx
forum.
Thanks
Ciao
Gigi
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
举报
更多回帖
