Microchip
直播中
傅筹更
7年用户 192经验值
私信 关注
[问答]
ICD3在特定设备上被阻止
大家好,我在MPLAB X 3.15(Wi7 64位)上使用了我的ICD3遇到了一些麻烦。我开发了一个基于DSPIC30F6010A的项目,所有的工作都很好,因为我开始在一个基于DSPIC33 EP256MU810的新项目上工作,我的ICD3不再能够识别和编程设备……通过改变ICD3,新工具运行良好。我已经尝试基于DSPIC30F6010编程旧板,问题仍然存在。回到基于DSPIC306010A的项目中,根据DSPIC306010A返回项目,异想天开的ICD3工作得很好。看来我的工具被“阻塞”了。一个DSPIC30F6010A。我已经验证了正确的固件是在工具上下载的,但是不同于DSPIC30的设备…无法识别。我如何恢复我的ICD3到工厂设置?谢谢你的帮助!伊蒂
以上来自于百度翻译
      以下为原文
    Hi all,
I'm experiencing some troubles using my ICD3 on MPLAB X 3.15 (Win7 64 bit).
I've developed a project based on dsPIC30F6010A, and all work fine; since I begin to work on a new project based on a dsPIC33EP256MU810, my ICD3 is no more able to recognise and to program the device...
by changing the ICD3, the new tool works fine.
I've tryied to program an old board based on a  dsPIC30F6010, and the problem persists.
Coming back to the project based on the dsPIC306010A, Returning to the project according to dsPIC306010A, the whimsical ICD3 works well.
It seems that my tool is "blocked" to work on a dsPIC30F6010A.
I've already verified that the proper firmware is downloaded on the tool, but devices different from dsPIC30... are not recognised.
How can I restore my ICD3 to the factory settings?
Thank you for your help!
iTTy
回帖(10)
李兆峰
2019-3-19 13:56:08
也许重新上传原始固件?(类似的事情也发生在我身上)
以上来自于百度翻译
      以下为原文
    Maybe re-upload original firmware?
(something similar was happening to me too)
举报
陈晓晨
2019-3-19 14:03:38
我已经尝试通过指向路径:C:程序文件(x86)/Microchip /MPLABX/V3.15/MPLABBIDE/MPLABLIbs/MuleS/Ext/ICD3.JAR/ICD3FWY01400 5.JAMEL方式下载固件?伊蒂
以上来自于百度翻译
      以下为原文
    I've already tried to force the firmware download by pointing to the path:
C:Program Files (x86)/Microchip/MPLABX/v3.15/mplab_ide/mplablibs/modules/ext/ICD3.jar/ICD3FW_014005.jam
Other way to download the firmware?
iTTy
举报
陈晨
2019-3-19 14:22:09
试试V3.61,看看问题是否已经解决了。
以上来自于百度翻译
      以下为原文
    Try it with V3.61 and see if the problem has been fixed.
举报
陈晓晨
2019-3-19 14:37:17
谢谢你的回复!这个晚上我会尝试改变MPLAB X版本…但是要确保下载一个正确的ICD3固件,我在哪里可以找到正确的文件?另一个问题:什么会引起这个问题?
以上来自于百度翻译
      以下为原文
Thank you for your replies!
This night i will try to change MPLAB X version...
But to be sure to download a right ICD3 firmware, where can i find the proper file?
Another question: what can cause this issue?
举报
更多回帖
