在“选择调试TARGRT”窗口中,我找不到MINI PROP3的信息,所以我不能进行片上调试。
我已经重新安装了PSoC创建者1和MIIPROP3的驱动程序,但是创建者仍然没有得到MIIPROP3。
PSoC程序员可以得到并编程PSoC3芯片。
我用PSoC Creator 1在另一台计算机上测试了我的MIXPRO3,它可以得到MIIPROP3。
你能告诉我怎么修理吗?
PSoC Creator:1生产[1.0.0.77 27 ]
MIN PROP3版本:2.05〔2.68/1.07〕
MIN PRO3驱动程序:3.4.1.20
谢谢你
安德森
以上来自于百度翻译
以下为原文
I can't find the informa
tion of mini-prog3 at "Select Debug Targrt" windows, so I can't doing on-chip-debug.
I had re-install the PSoC Creator 1.0 and the driver of mini-prog3, but the creator is still not get the mini-prog3.
The PSoC Programmer can get that and programming the PSoC3 chip.
I had test my mini-prog3 at another computer with PSoC Creator 1.0, and that can get the mini-prog3.
Could you tell me how can I fix that?
PSoC Creator : 1.0 Production[1.0.0.7727]
Mini-prog3 version : 2.05[2.68/1.07]
Mini-prog3 driver : 3.4.1.20
Thank you
Anderson
