Hi Boaz - 在E4438C中有三个用于列表扫描的SCPI命令。
每个矢量都在构成扫描三个元素的3个矢量之一上工作:频率,幅度和驻留。
例如,要配置下面列出的扫描,请使用以下SCPI命令:频率向量:: SOURce:LIST:FREQuency 1e6,10e6,20e6功率向量:: SOURce:LIST:POWer -2,-3,-3 Dwell vector:
:SOURce:LIST:DWELl 2e-3,2e-3,2e-3这些命令将作用于当前列表扫描点。
现在,为了添加另一个扫描点,您必须重新发送这三个命令。
例如添加第4个元素:: SOURce:LIST:FREQuency 1e6,10e6,20e6,30e6幂向量:: SOURce:LIST:POWer -2,-3,-3,-2 Dwell vector :: SOURce:LIST:DWELl
2e-3,2e-3,2e-3,2e-3问候 -
以上来自于谷歌翻译
以下为原文
Hi Boaz -
There are three SCPI commands for list sweep in the E4438C. Each works on one of the 3 vectors that make up the three elements of the sweep: Frequency, Amplitude, and Dwell.
For example to configure the sweep that you list below use the following SCPI commands:
Frequency vector:
:SOURce:LIST:FREQuency 1e6,10e6,20e6
Power vector:
:SOURce:LIST:POWer -2,-3,-3
Dwell vector:
These commands would act on the current list sweep points.
Now, in order to add another sweep point you have to resend the three commands. For example to add a 4th element:
:SOURce:LIST:FREQuency 1e6,10e6,20e6,30e6
Power vector:
:SOURce:LIST:POWer -2,-3,-3,-2
Dwell vector:
:SOURce:LIST:DWELl 2e-3,2e-3,2e-3,2e-3
Regards -
以上来自于谷歌翻译
以下为原文
Hi Boaz -
Frequency vector:
Power vector:
Dwell vector:
Power vector:
Dwell vector:
Regards -
举报
